Exhaust Cackle
Exhaust Cackle
Postby HaWk » Tue Apr 05, 2005 7:25 pm
As stated, i have an exhaust cackle when i get over 2000rpm and i have had my exhaust checked out but no rattles or anything loose in the system so it must be a bung resonator or tip, but im kinda thinking it could b resonator as it's prob pretty old n $&#$% but if anyone could verify a better way i finding out wich of the two it is or knows if it definitly is my resonator could u let me know? kinda low on dough so dont wana get new system etc
Thanks, wuv da yotas!
HaWk
Postby rettun » Wed Apr 06, 2005 11:52 pm
I've got the same problem.. if u jack it up you can figure out aprox where the rattle is if u trust layin under ur car while its running
rettun
Postby Dr-X » Thu Apr 07, 2005 9:53 am
It'll probably be the exhaust heat shielding
Dr-X
Postby BZ Touring » Thu Apr 07, 2005 1:37 pm
Yep, agreed. I had the same issue, where I'd get the same noise at around 2,000 - 2,500 rpm. It turned out that the heat sheilding under the cat had been damaged and pushed up against the cat, resulting in a resonance at a certain rpm. I just had it pulled back...no more noise...sweet.
BZ Touring
Postby HaWk » Tue Apr 12, 2005 9:25 pm
but im pretty sure i dont have a cat converter, so could it still b the heat shield?
HaWk
Postby Dr-X » Tue Apr 12, 2005 9:51 pm
Yes. Have you ever looked under your bonnet?
Dr-X
Postby AJz » Tue Apr 12, 2005 9:52 pm
i hav the same sorta problem, sounds like a honda taking off, lol.
Im just gonna fix it eventually with a new full zaust and custom headers. suits me :D
I had vtax :(
AJz
Postby HaWk » Tue Apr 12, 2005 11:15 pm
Dr-X wrote:Yes. Have you ever looked under your bonnet?
yes of course i have, was there a point to that post?
HaWk
Postby Dr-X » Tue Apr 12, 2005 11:22 pm
HaWk wrote:but im pretty sure i dont have a cat converter, so could it still b the heat shield?
You should see the heat shielding - it's the big pieces of metal bolted over top of the exhaust manifold, and wrapped around the exhaust pipe.
Dr-X
Postby HaWk » Wed Apr 13, 2005 9:28 am
ok thanks il get it up on the jack at work today n see wats up.
thanks for ya help dudes
HaWk
