wildcard wrote:A tossup between mods with lesser technical knowledge vs those with obvious attitude problems would see the former win any day. For those on their own hobby horses - get off them, its not helping as things progress here. Since this thread has been hijacked off topic, its now locked and I have moved the 3 useful posts that were on topic to a new topic in tech. Please continue there.
Mr Revhead wrote:interesting.... what power revs they running?
they didnt crack casue of conrods did they?
Mr Revhead wrote:going by the rest of there info, it seems they maybe reffering to mega hp builds... weak blocks are certainly not a common 3sgte (or any toyota) trait that iv ever heard of before.
That sort of comment is hardly called for, and not what I'd expect from a more mature member of this forum, perhaps an apology is in order
Mr Revhead wrote:if you have some reading of the "503e" avail id be keen to see it as its not easy to find.
the comment was meant in semi jest.... his actions were a bit over board.
as for the moderation, how do you propose its fixed? its not feasible to have mods who are 100% correct in tech all the time, and if they dont know its incorrect how can they fix it? and as i stated before, i think keeping incorrect posts can be useful, when they are rebutted with the correct info. if they are deleted then the same mistakes will keep being made.
you reckon stress risers, so it would be prudent to do some block prep, eg deburring when building a 3s engine? thats if the stress points arnt inside the water jacket.... which would seem the most likely place to me.
fivebob wrote:I've go more info but I don't have the books to hand so this will have to suffice for now.
(CUT)
IIRC When used at LeMans this engine had approx 680HP in qualifying trim and 580HP in race trim.
