4AGE 16v 8.9:1 pistons in 20v - Flycut or not?
Postby Gavin » Wed Apr 13, 2005 7:00 am
I'm building a 20v for boost. Realistically, should I bother flycutting my AE101 4agze pistons for the 5 valve head?
ADMIN EDIT: stupidly large image removed
20v Powered AE92 wagon (20v turbo project)
78 280z Black Pearl Edition AutoX'er
Gavin
Postby RedMist » Wed Apr 13, 2005 7:30 am
Gavin, if you can get away with it most certainly do NOT flycut your pistons. It disturbs flame propogation and will ultimately create slightly less HP.
It depends on cam duration,lift and timing. However as your running a boost application I doubt very much that you'll have to do anything about flycutting.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby Gavin » Wed Apr 13, 2005 9:12 am
I was thinking along those lines. The gze pistons are ceramic coated also.
I will be using stock cams. If anything I may updrade to the highter lift blacktop intake cam.
So CAN I get away with it? Any horror stories out there?
Gavin
Postby Mr Revhead » Wed Apr 13, 2005 1:02 pm
wont need to do that, there is no clearance issues with the 4agze pistons.
bolt it on and away you go!
Postby Gavin » Thu Apr 14, 2005 3:18 am
Awesome thanks a lot.
Gavin
Users browsing this forum: Google [Bot] and 25 guests
