alternator might be crapping itself
Postby Santa'sBoostinSleigh » Wed Apr 13, 2005 8:45 pm
How can i tell if my alternator is gunna sh!t itself?
indicators/wipers/bass from sub/elects windows all seem to be dimming my lights lately - would that be an alternator trying to tell me its gunna go *poof* on me soon?
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby Crimson Tears » Wed Apr 13, 2005 10:20 pm
Those auxilliary devices will cause your lights to dim because they cause a voltage drop in the system. A good indication your alternator has a problem is the charge light on the dash which may come on with any other combination of lights on the dash while the engine is running.
If you want to check the alternator is charging, you can use the following procedure:
With the engine stopped, connect a voltmeter between the negative and positive terminals of the battery. The reading should be approx 12.6volts.
Start the engine, and the voltage reading on the voltmeter should increase as the engine speed is increased. If this does not occur, the alternator is not charging.
Increase the engine speed gradually. At a moderate engine speed, (around 1500rpm) the voltmeter should flicker slightly, then remain stationary at around 14 volts. This is the regulated voltage.
Switch on the headlamps of the vehicle and observe the effect on the voltemeter. The voltage reading should drop slightly, but still remain stable.
Cheers,
Mike.
Crimson Tears
Postby B_giB » Wed Apr 13, 2005 11:47 pm
also, while engine running, disconnect battery -ve terminal, if engine dies its alternator, had that with my AE86
Current: SXE10 Altezza
AE101 Levin 20V super strut
1994 Mercedes Benz C280 Sport
B_giB
Postby ee904age » Thu Apr 14, 2005 6:11 pm
B_giB wrote:also, while engine running, disconnect battery -ve terminal, if engine dies its alternator, had that with my AE86
Ummm, thats wrong for sooo many reasons.
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby gtz666 » Thu Apr 14, 2005 7:44 pm
i'd do that voltage test with the multimeter and also if you have dropped a phase or so it wont be picked up on this test with the meter
gtz666
Postby Santa'sBoostinSleigh » Mon Apr 18, 2005 10:19 pm
any other ideas?
Santa's Mega Sale
Postby dohca » Mon Apr 18, 2005 10:21 pm
tryed new battery?
dohca
