fuel filters
fuel filters
Postby LEV_101 » Thu Apr 14, 2005 8:18 pm
can someone tell me whats the point in changing the fuel filter ? and how long we should change it ? thanks !!!
LEV_101
Postby dazzag » Thu Apr 14, 2005 8:23 pm
the fuel filter takes any dirt or foreign objects out of the fuel. If the fuel filter wasnt there there would be a good chance something could either get blocked in your fuel lines, fuel injectors, carbuerator or even damage or scratch your cyclinders. It depends what car you have???? usually around 50-70kms
dazzag
Postby dazzag » Thu Apr 14, 2005 8:24 pm
if you dont change it then it will get clogged affecting your engine perfomance
dazzag
Postby Mr. Mainstream » Thu Apr 14, 2005 8:32 pm
dazzag wrote: usually around 50-70kms
are you serious? 8O
Current:77 MK2 Ford Escort L 1.3L
75 MK2 Ford Escort L 2.1L
Had: 2X Early Subaru Leggys GT Wags, 1X Subaru RS, 1X 2004 Subaru B4, 2x BFMP Turbo Sedan Famil's, 2x BFMR Turbo Sedan Famil's, AE92 FX-GT, 97 Holden Calais 3.8L
Supercharged 12psi ,Escort, BZ-R
Various Others
RomanV wrote: Mr Mainstream: The king of the Pushrods?!
Mr. Mainstream
Postby Lloyd » Thu Apr 14, 2005 8:40 pm
Not like its hard... usually. Do it at every 50,000 if you want. Should be right with 100,000kms. Unless you're throwing dirt in with your petrol :P
Postby LEV_101 » Thu Apr 14, 2005 9:03 pm
ooo ... is there like trd fuel filters i can buy ??? for a levin 4age ae101 ?and how much if anybody knows ...
LEV_101
Postby Lloyd » Thu Apr 14, 2005 9:14 pm
Do you need a TRD one? Seriously, all they would do would be flow better and possibly filter worse at an extra cost to your pocket. PM Mr Revhead if you're after a decent price on Toyota/TRD bits
Postby TrouserFxGt » Thu Apr 14, 2005 9:29 pm
I changed mine about 2 months ago and back flushed it at work and it was full of crap. I'm assuming it was 125,000k's old.
Toyota ones are around $60-$65.
Use that and you'll be fine. What gains do you think a trd filter (if they make them) will give you? Que scribe...........not many if any
Alcohol, The cause of and solution to all lifes problems.
H J Simpson.
TrouserFxGt
Postby Mr Revhead » Thu Apr 14, 2005 11:22 pm
they are worth 10hp in a 20v
:lol:
not, they dont do them.
fuel filter is a basic (if often overlooked) maintanence item.
should be replaced first service after buying a car i reckon.
Postby Dr-X » Fri Apr 15, 2005 12:33 am
are you serious? 8O
As in 50,000 - 70,000 kms :roll:
Dr-X
Postby LEV_101 » Fri Apr 15, 2005 8:26 am
if i buy one myself .... is it easy to install ??? does anybody know how much are toyota/ trd fuel filters ???
LEV_101
Postby Bling » Fri Apr 15, 2005 11:05 am
just go to repco and get one, its only a filter, and isn't really a 'performance' item, so why bother (i think revhead said they don't do them anyway), and yes its easy to change.
Postby NA Drifter » Fri Apr 15, 2005 11:41 pm
yeah, u will be suprice how much dirty stuff pouring out from the old filter. all the fuel just brown.... 8O
Keith
NA Drifter
Postby Spannergal » Sat Apr 16, 2005 11:59 am
Mr Revhead wrote:they are worth 10hp in a 20v
:lol:
besides which they're not visible unless maitenance is being done on a lot of cars so there's no point doing TRD fuel filters :lol:
Spannergal
Postby dazzag » Sat Apr 16, 2005 3:59 pm
hey i just looked at the toyota service schedule says the filter should be replaced every 80,000kms or 4years whatever comes first. they arent too hard too replace. its sometimes easier to remove the airfilter and air intke hose out of the way to acess it.undo the top hose bolt i think its a 17mm has two washers on it. then undo the bolt underneath. can be a lil tricky, you may need a pipe wrench or pipe socket for it. Then theres two 10mm bolts that mounts the filter. remove them and bobs your uncle.
dazzag
Postby CozmoNz » Sun Apr 17, 2005 10:02 am
BZG|Bling wrote:just go to repco and get one, its only a filter, and isn't really a 'performance' item, so why bother (i think revhead said they don't do them anyway), and yes its easy to change.
have you TRYED doing one in an ae111?
worse place ever to mount them >.>
*right in the middle*, you need 2 bloody people to do it easily!
Rayne For President!
CozmoNz
