powerstearing fluid
powerstearing fluid
Postby minijrocks » Sat Apr 16, 2005 8:22 pm
hi, i seem to be running a little under the required amount of powerstearing fluid. where can i get some , how much?
minijrocks
Re: powerstearing fluid
Postby Snoozin » Sat Apr 16, 2005 8:24 pm
minijrocks wrote:hi, i seem to be running a little under the required amount of powerstearing fluid. where can i get some , how much?
Go to Woolworths, aisle 13, powersteering and other assorted fluids (excluding bodily). :roll:
Just let your fingers do the walking I say.
Failing that..... you COULD at a push try Repco.
Snoozin
Postby minijrocks » Sat Apr 16, 2005 8:29 pm
how much. am i going to have to buy some 10 litre bottle just for about 30mls :roll: ?
minijrocks
Postby fangsport » Sat Apr 16, 2005 8:34 pm
if it is only 30mls, don't worry about it.
normally available from 250ml bottles upwards.
fangsport
Postby Dr-X » Sat Apr 16, 2005 9:11 pm
Have you tried actually going to Repco to look for yourself? I know it seems a silly idea, but just try it :roll:
If you're low on PS fluid, you may want to investigate why.
Dr-X
Postby Lloyd » Sat Apr 16, 2005 9:41 pm
And you probably shouldn't go looking for a bottle of power steering fluid since its actually ATF (Auto Trans Fluid). Probably have to buy about a litre of it, not sure if it comes in smaller bottle. Failing that you could pop into a garage and ask them to top it up for you
Postby dazzag » Sun Apr 17, 2005 6:23 pm
most car places will have it. its the same as automatic trans fluid so dont be suprised if you cant find any power steering fluid
dazzag
Postby BlakJak » Sun Apr 17, 2005 7:34 pm
Repco have it and have it labelled as PS fluid, but you will wind up spending on 250ml or so as a minimum. I still have some from when I was topping mine up constantly.
It is the same as AT Trans fluid but its not hard to find.
BlakJak
Postby CozmoNz » Sun Apr 17, 2005 8:28 pm
you just know they will be selling *Ps fluid* for $9.90 for 250mls, and a litre of *Auto trans fluid* for $9.90 :).
Rayne For President!
CozmoNz
Users browsing this forum: Bing [Bot] and 13 guests
