CT20B...
CT20B...
Postby Dell'Orto » Sat Apr 16, 2005 8:43 pm
Ok, so I finally got around to putting the CT20B in my car...oil and water lines - sweet, bolt up nice.
Actuator and boost controller lines - yup, sweet, just like before. Manifold bolts on sweet as.
I go to do up the turbo hanger bolt - wtf? The bolt hole is about 20mm away from the turbo hanger, and there is bugger all movement.
Have I stuffed something up, or do you need to use a gen 3 turbo hanger to make the CT20B work with the Gen 2 motors??
Postby Dell'Orto » Sun Apr 17, 2005 12:18 am
Think I have it sorted - apparently when you go to a CT20b you just throw the hanger away :D
Bit less weight I guess!
Postby CozmoNz » Sun Apr 17, 2005 9:55 am
So, hows the difference?
Rayne For President!
CozmoNz
Postby Wildcard » Sun Apr 17, 2005 11:31 am
I'd still recommend having a hanger fabricated up to stop excess stress being put on the manifold studs etc....
Wildcard
Toyspeed Founder
Postby vvega » Sun Apr 17, 2005 11:59 am
castings can move when there very hot so in time with no support you may find it gets a bit droopy :D
this will esculate any small cracks and defects in the casting and you might find you will also end up with that oh so annoying "tick-tick" :D
:D
v
vvega
Postby Al » Sun Apr 17, 2005 7:29 pm
His new downpipe will have bracing, that will sort it. Mines all good :D
Al
Postby Dell'Orto » Sun Apr 17, 2005 8:39 pm
Wildcard wrote:I'd still recommend having a hanger fabricated up to stop excess stress being put on the manifold studs etc....
What did you use with your new turbo?
CozmoNz wrote:So, hows the difference?
Same as before, still not running :lol: Give it a few more weeks/months :D
vvega wrote:castings can move when there very hot so in time with no support you may find it gets a bit droopy :D
I still have the hanger underneath it, just no bolt through it. Stupid monkeys who did the last turbo rounded off one of the nuts, so I pretty much have to leave it on :lol:
Postby Twolitre » Mon Apr 18, 2005 12:18 am
Not even the Gen3 turbo -> block bracket works or I would've sent it to you as well as the turbo, the positioning of the turbo via the exhaust manifold must be different as the exhaust housing itself is physically identical to the CT26
Even with a braced DP you will probably be more likely to crack your manifold as the pair still weigh quit a bit but Gen2 manifolds are cheap and easy to come by so don't worry too much.
Twolitre
Postby Dell'Orto » Mon Apr 18, 2005 1:55 pm
Twolitre wrote:Not even the Gen3 turbo -> block bracket works or I would've sent it to you as well as the turbo, the positioning of the turbo via the exhaust manifold must be different as the exhaust housing itself is physically identical to the CT26
Oh really? Stink :( Ah well, maybe I'll need to coerce my downpipe builder into making me a custom manifold too [/hint] :lol: :lol:
Users browsing this forum: Bing [Bot], Google [Bot] and 15 guests
