rev counter wires
rev counter wires
Postby Ae92typeX » Sun Apr 17, 2005 9:56 pm
As I was looking through my box of bits today I found an old sanpet rev counter & thought I might put it in the mini, however, ive lost the wire diagram, and when I took the back off, its got another cover over it all so I cant see which wires are for the bulbs/coil.
at a pinch, before I dismantle it I thought I'd see if anyone knows:
4 wire colours:
red, white, green, black.
Cheers :)
Ae92typeX
Postby NA Drifter » Mon Apr 18, 2005 12:09 am
i will have a guess at..
red=power
black=ground
Green=tachco input/ignition coil negative terminal
White=light
good luck
Keith
NA Drifter
Postby TygerTung » Mon Apr 18, 2005 12:21 am
Either that or the green is for the light and the white is for the tacho.
TygerTung
Postby matt dunn » Mon Apr 18, 2005 12:35 am
NA Drifter wrote:i will have a guess at..
red=power
black=ground
White=light
good luck
I would agree with this.
The only other way I think it may be wired is swap the green and white.
You will not do any damage to it with those wires around the wrong way anyway, as long as you have the red and black correct.
Matt
Postby Dr-X » Mon Apr 18, 2005 9:25 am
Green is coil, white is light.
Dr-X
Postby Ae92typeX » Mon Apr 18, 2005 12:21 pm
sweet, cheers all,
assuming its still in working order I'll confirm the wires tonight.
Ae92typeX
Postby Ae92typeX » Mon Apr 18, 2005 5:37 pm
NA Drifter wrote:red=power
black=ground
White=light
100%
sweet, cheers.
Ae92typeX
Postby NA Drifter » Mon Apr 18, 2005 6:13 pm
Cool, Now all you need to do is, take a pic showing ur Mini revving it at 10,000RPM :D
Keith
NA Drifter
Postby Ae92typeX » Mon Apr 18, 2005 7:45 pm
lol, but then I would have to dismantle it again for a rebuild :lol:
Ae92typeX
Postby 85AW20v » Tue Apr 19, 2005 9:55 pm
My brothers 1340cc Targa Mini went to 7500 all day. He was getting 100hp at the wheels on the last dyno run he did. We never had any shortblock problems - only idler bearings in the end cover of the gearbox and he'd got a bit too enthusiastic with the die grinder in the head but Irontite fixed it for the duration of Targa. Got it welded after that.
See ya
Simon
85 MR2 20v
85AW20v
