Quad throttles
Quad throttles
Postby Lloyd » Fri Apr 22, 2005 9:03 pm
Alright, just wanting to clear something up. Every time I hear someone talking about putting quad throttles onto a 16V head I always seem to hear something along the lines of "Oh, and you'll need a different ECU". Why exactly do people think this?
Postby vvega » Fri Apr 22, 2005 9:18 pm
different size injectors :D
v
vvega
Postby Lloyd » Fri Apr 22, 2005 9:31 pm
Ah, thats a semi-logical reason. Hardly justifies a complete ECU replacement.
How goes the 20V 7AGTE btw? Hopefully get some pics of my 20V turbo motor tomorrow :D
Postby ChaosAD » Fri Apr 22, 2005 10:08 pm
According to Club4ag they require more fuel at full throttle and less fuel at low throttle (compared to the standard manifold). Thus requiring a replacement ecu.
However if you search the club4ag website there are people running them with standard computers.
Whether they actually gained any power from the conversion is a different story.
ChaosAD
Postby toyonut » Sat Apr 23, 2005 10:57 am
Are quad throttles it a worthwhile conversion?
I want to adapt 20v quads to my 3sge, is it possible?
the only other problem is that the 3sge is mounted in a MR2 and as such has not a lot of room, but a measuring tape should solve this problem.
I have read that the boosted performance ute has a 3sge with the levin quads and runs fine with no tuning.
I dont think it should be too hard to adapt the throttles to the manifold (i can play at work on the weekends), and the pipework to the manifold should be easy to sort out because i appear to have no AFM even though it is a 1990 model. :?
toyonut
Postby Adamal » Sat Apr 23, 2005 12:28 pm
Karl Skewes has put 20v silvertop quads on a 3SGE before.
Theres some documentation on his website, can't remember the address though.
He had it running in an FR setup, so there would have been a bit more room... If I recall, he had to customise a mounting bracket for it.
Postby Drifter4ag » Sun Apr 24, 2005 5:31 pm
visit the website and look .. www.garagedori.com
20v throttles on the 3s were great .. very powerful
i run 20v throttles on a big port 4age
using standard injectors are fine .. long as your manifold will let you get away with standard rail like mine does. And run a 2nd or 3rd gen Apexi superafc or something as this has enough scope to tune out any inconsistencies
Results on mine were pretty average but i would expect better with a decent motor ie not a dead/dying engine (mine loses around2-3kw
@wheels permonth) so from changing to quads i gained about 4kw@wheels on this motor. On a good motor i would expect anything up to 10kw@wheels with right tune.
Response is the main thing oh .. and it sounds freaking wicked :twisted:
Garage |-" '|
Current Rides
AE86 Notchy (Finally through compliance after 5 years)
Vitz RS :D
Previous,
1x SXE10 Altezza, 2xAE111 Caribs, 3xKP60, 2xke35 SR Coupes, 2xAE85s, 2xAE86 Road Car, 1xAE86 Drift Car 182kw@wheels, 1xJZZ30 Drift Car 360ps
Panspeed Special 450ps Drift Car
JZX91 MARK II CHASER
JZX81 MARK II CHASER..... so many more that i forgot....
Drifter4ag
Postby ChaosAD » Sun Apr 24, 2005 6:55 pm
How did you hook up the map sensor?
ChaosAD
Postby Lloyd » Sun Apr 24, 2005 7:57 pm
There are a couple of hoses hooked up to all throttles so a MAP sensor feed isn't an issue.
Postby ChaosAD » Sun Apr 24, 2005 8:29 pm
But what about the vacum spikes? do you just use a buffer? like a fuel filter or some other restriction?
ChaosAD
Postby Silent Knight » Mon Apr 25, 2005 2:51 pm
Hrmmm I'm very interested with this conversion myself as I am thinking about playing around with Quad Throttles on the 1J.
Silent Knight
Postby Adamal » Mon Apr 25, 2005 3:12 pm
Quad throttles on a 1J? Or do you mean individual throttles on a 1J?
Postby Silent Knight » Mon Apr 25, 2005 4:49 pm
Adamal wrote:Quad throttles on a 1J? Or do you mean individual throttles on a 1J?
I mean alter the Quad Throttles from a 20V to fit on a 1JZ. I've only ever thought about it once or twice but I am really interested to start toying around with the idea.
Silent Knight
Postby rxtoy » Mon Apr 25, 2005 4:53 pm
i seem to remember one of the main benefits of quad's being that the throttle body is right next to the inlet so throttle response is heaps quicker. don't know how noticeable it would be.
i'm thinking about having a go at adapting a set to my RWD lancer turbo (need to upgrade the inlet manifold anyway cause its crap single point injection), have to see if i have the time though, already got enough damn projects.
Matt
current rides:
76 stout
77 B1600 13B J port
rxtoy
Postby YeMs » Mon Apr 25, 2005 8:01 pm
i pulled a set off a silvertop at a wrecker and paid F***all for them. now im considering making an adapter to set them up on my 3tgteu... i guess ill see wen its finished if they make a difference. and if it doesnt really ill sell the design to sum young clown with a 3tgte and tell him it makes a huge difference ;)
Your local Hybrid Elite tech
YeMs
Postby Drifter4ag » Tue Apr 26, 2005 11:30 am
no point if you are running a turbo
just big throttle body and large plenum.
Basically running quads is the same as running carbies minus the restriction of the jets and the fact you have fuel controll to fanatastic levels.. quads let the old bluey rev out to ... even a stock motor can hit 10k 8O
Garage |-" '|
Current Rides
Vitz RS :D
Previous,
Drifter4ag
Postby rxtoy » Tue Apr 26, 2005 5:40 pm
why no point for a turbo? should still make a difference, would it be too minimal to bother with the effort (i could bolt up a VR4 inlet manifold, just the throttle body faces the wrong way so i'll have to modify anyway)???
Matt
current rides:
76 stout
77 B1600 13B J port
rxtoy
Postby Drifter4ag » Tue Apr 26, 2005 8:03 pm
How much power do you want ?
If you are running a 20v head then sure go for it ..
otherwise just run either custom plenum or even standard intake manifold .. you can get in excess of 300hp with standard manifold.
Garage |-" '|
Current Rides
Vitz RS :D
Previous,
Drifter4ag
