Actual 4AG Dyno Figures
Postby ee904age » Tue Apr 26, 2005 9:24 pm
I have done a search but only really come up with Toyota's quoted figures.
Does anybody have actual dyno figures of stock (or nearly) 4AGE's???? Any models, mainly interested in 16V's.
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby Lloyd » Tue Apr 26, 2005 9:28 pm
One unmodified (pretty much) one here
http://www.garagedori.com/tech/index.php
Postby NA Drifter » Tue Apr 26, 2005 9:39 pm
i have one for my ae86, but that's redtop block with bluetop head, so running tvis etc... 4-1, 2" and filter, std ae86 ecu.
got about 85kw at wheel. Done it down here in Palmy at Fortec Performance which is same as Torque Performance dyno.
Keith
NA Drifter
Postby ee904age » Tue Apr 26, 2005 9:44 pm
"First off, a baseline, the bluetop 4AGE in my AA60, out of an AA63 Carina. It has trd headers, 2" exhaust with reso + muffler, no air filter."
Result 85.18kw ATW!
Pretty impressive, I thought the factory output was "inflated" at 88kw at the fly?
90 SW20 N/A - Sold
ee904age
Postby 4AGE 8U » Tue Apr 26, 2005 10:36 pm
i've got a blacktop 4ag and i made 113kw, untuned running real rich, mods are zorst and mild cams
4AGE 8U
Postby Malcolm » Wed Apr 27, 2005 12:06 am
ee904age wrote:"First off, a baseline, the bluetop 4AGE in my AA60, out of an AA63 Carina. It has trd headers, 2" exhaust with reso + muffler, no air filter."
Result 85.18kw ATW!
That's probably on the Torque Performance Dyno. For some reason their figures often seem to be about 15-20% more than you'd expect. Good way to get business I suppose (would you rather go to a dyno where you'll get 80kW or one where you'll get 100kW?)
Postby Drifter4ag » Wed Apr 27, 2005 12:43 am
ahah ..i love those torque performance ++ power claims ..
there dyno is inline with world standards and all dynos we have from them are in shootout(which runs set peramiters with minimal correction) mode just as they are in aussie and the USA .
Reads higher .. i took my turbo ae86 to another rolling road dyno using different software and it read 2kw higher on their dyno. RX7Heaven i think it was .. east tamaki somewhere
Can scan that one in also but didnt really think it was worth anything
Only dynos that are apparently high readers are the Hub dynos.
Near stock 4age is Karls .. only the headers and no airfilter were the mods..
mine with stock intake and coby headers was putting out 82kw@wheels
A good bluetop in RWD trim will make 85+kw@wheels .. and slightly more in FWD
Garage |-" '|
Current Rides
AE86 Notchy (Finally through compliance after 5 years)
Vitz RS :D
Previous,
1x SXE10 Altezza, 2xAE111 Caribs, 3xKP60, 2xke35 SR Coupes, 2xAE85s, 2xAE86 Road Car, 1xAE86 Drift Car 182kw@wheels, 1xJZZ30 Drift Car 360ps
Panspeed Special 450ps Drift Car
JZX91 MARK II CHASER
JZX81 MARK II CHASER..... so many more that i forgot....
Drifter4ag
Postby Malcolm » Wed Apr 27, 2005 12:48 am
so you're saying Toyota (and most other manufacturers, as I've seen several stock cars put out more than you'd expect on dyno's), actually underquote their power figures? No, I think the problem is that most rolling road dyno's just aren't that accurate. Good for comparisons (before mods/after mods), but they always seem to produce figures far higher than you'd expect them to. Unless I've been mislead, and typical drivetrain losses are around 2%, rather than the 15-20% most people claim
Postby EVLGTZ » Wed Apr 27, 2005 8:55 am
All_Fours wrote:Unless I've been mislead, and typical drivetrain losses are around 2%, rather than the 15-20% most people claim
15% to 20% is a lil high. try 10-12% fwd and 15% at most for rwd.
I've got no issues with using TP dyno figures to state claims. I've run on others with very similar results and also a hub dyno which was higher (as expected).
If ya looking for some good 4age dyno plots then the garagedori ones are pretty good to go by.
Having said that I've also seen a number of bluetops put out only 75-80kw on the TP dyno.
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
Postby Silvertop » Wed Apr 27, 2005 9:20 am
We have had a few bluetops run on a hub dyno down in Welly lately:
75.xfwkw - (250,000k's + I/H/E)
90.4fwkw - (same car 2 weeks later - I/H/E + engine recon + raised compression + mild cams)
The same dyno has run several stock silvertop 20Vs with figures that range from 77 - 92fwkw, blacktops 90 - 100fwkw.
I'll try to get their dyno plots posted up as a peak power figure doesn't tell the full story ;)
Silvertop
Postby B1NZ » Wed Apr 27, 2005 9:29 am
Silvertop wrote:The same dyno has run several stock silvertop 20Vs with figures that range from 77 - 92fwkw, blacktops 95 - 100fwkw.
you mean 90-100kw for blacktops, Chris's old one made 92kw, Mine has 95.5kw which i would consider middle of the road/average
Pc's powergain was pretty impressive really when you think about it! 8O
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby Silvertop » Wed Apr 27, 2005 9:47 am
Silvertop
Postby Drifter4ag » Wed Apr 27, 2005 10:09 am
i wouldnt say misquote ... but that all power figures stated are measured as a peak of performance and are probably not guaranteed :) .
Please see Orcon internets terms and conditions :P realating to their "bitstream" product. Then you get the idea
Toyota can make 500000 of the same engine .. you think they all will have 88kw ? I think not .. there will be the majority that are 88kw or there abouts but there will be exceptions where balancing is more acurate from factory yielding greater results and those that are slightly poorer but still within limits thus the slower motors putting out under 88kw.
To sum it up -
Heres the motor we built with its "safe fueling" etc
Lets Engine dyno 1000 out of 100000
Average them out - thats the power figure we get or along those lines and thats what is advertised
Garage |-" '|
Current Rides
Vitz RS :D
Previous,
Drifter4ag
Postby samlloyd » Wed Apr 27, 2005 12:25 pm
My 76 escort had 62kw at the wheels.
Karl Pilkington On seals - "Its between a fish and a dog."
samlloyd
Postby JT » Wed Apr 27, 2005 5:34 pm
Result 85.18kw ATW!
The bluetop 16V as found in ae86 is often misquoted as 88kw. It is in fact rated 96kw from all the toyota advertising material I've seen. I'm pretty sure it's the red/black top TVIS 4age that is rated 88kw and the red top small port (no TVIS) is rated 100kw.
My rwd bluetop made 83kw atw on colomus car clinic dyno with just the usual filter and exhaust.
That's one ugly torque curve 8O
JT
Postby Loudtoy » Wed Apr 27, 2005 7:10 pm
Silvertop wrote:We have had a few bluetops run on a hub dyno down in Welly lately:
Na your wrong my old one made 93kw on that dyno :P but your pretty close that was only intake and one extremely loud exhaust :twisted:
TS Member sine 2001
Prado To tow stuff with
Rodeo to do work stuff in
Loudtoy
Postby vvega » Wed Apr 27, 2005 7:42 pm
i got 86kw@wheels on a tired old bluetop... rolling road
and all that had was a pod... thats it... so thats about as stock as youll get
im a beliver that fwd's will suffer from 7-10% powerlosses
rwd is only worse as it has to go though one extra 90 dgree drive(crown and pinion) so id be 10-15%(dependant on a lot of factors) for that with the 15-20% saved for 4wd cars
just my thoughs...
v
vvega
Postby NZ_AE86 » Wed Apr 27, 2005 8:45 pm
I have no faith in Dyno's. They are great for comparing before and after or two cars but there are alot of factors that are missed. For example your factory AE86 could have one of 2 different Diff ratios, whose to say the correct ratio is put into the Dyno. This can make a difference of 5%.
So when someone tells you that they got blah blah blah KW at the wheels at the BLAH BLAH BLAH dyno day, chances are that it is incorrect. The time it takes on some front wheel drives to work out the correct ratio is more then they want to spend on each car at a dyno day!
Also, why do you want to know the factory output of a 4AGE?
NZ_AE86
Postby Drifter4ag » Wed Apr 27, 2005 8:51 pm
Ratios put into dynos are only relative to HUB dynos.
The final drive ratio in shootout mode makes no difference to the overall power figure.
And for the record all our runs are done in 4th gear as this is straight through 1:1 ratio on box -->diff.
Bluetops always seem to make more power than the old TVIS redtop .. TVIS redtop is the worst of the bunch in my opinion.
Garage |-" '|
Current Rides
Vitz RS :D
Previous,
Drifter4ag
Postby ee904age » Wed Apr 27, 2005 8:59 pm
Basically just want something to compare with when I get my engine finished.
90 SW20 N/A - Sold
ee904age
