caldina gtt boosting problem
Postby chadnz » Sat Apr 30, 2005 7:41 pm
iv just fitted a cold air box with pod filter and a new bov but it dosnt seem to boost as high way would this be its only boosting about 10 pounds it should be higher than that 12-15 iv been told is factory which is what it use to do.
im sure the bov isnt leacking can any one help cheers :cry: :?: :?: :cry:
chadnz
Postby WeNdY^cLeAr » Sat Apr 30, 2005 7:58 pm
i find it hard to belive it runs 15 psi factory..
WeNdY^cLeAr
Postby Silent Knight » Sat Apr 30, 2005 8:26 pm
WeNdY^cLeAr wrote:i find it hard to belive it runs 15 psi factory..
From what I know they do actually boost about 1bar from factory or very close to 1bar. 13-14psi from factory i think.
Silent Knight
Postby GT-T » Sun May 01, 2005 12:35 am
Since you put the new BOV in it,
it could have a leakage somewhere around the BOV...
1999 Caldina GT-T
2000 Merc A160
1998 Integra Type R
http://toyspeed.blakjak.net/profiles/profile.php?id=581
GT-T
Postby snwtoy » Sun May 01, 2005 12:12 pm
Got any pics of the cold air box?
If it's actually sucking warmer air, that could account for it not boosting as high..
What type of filter did you get? Apparently the generic shiny pods from 'rip every poor c* off' are not that great flow-wise..
snwtoy
Postby KiwiMR2 » Sun May 01, 2005 3:40 pm
AFAIA stock boost should indeed be about 13 psi.
KiwiMR2
2003 Estima 3.0L
2000 Opa
KiwiMR2
Postby fivebob » Mon May 02, 2005 7:33 am
Several possible causes for a lower boost, firstly I would check for boost leaks anywhere in the system, particularly the BOV. If that doesn't find the cause then I'd check to see if you've actually reduced the flow from the airbox which would cause a low pressure area before the turbo making it produce less boost.
Stock boost should be around 13psi but that varies depending on load & RPM, generally you'll only see that sort of level in the mid RPM range, from 3rd gear up (on a manual).
Postby Inane » Mon May 02, 2005 10:28 am
should run 12-13 psi in 1st and second (auto) and then 13-14 psi in third and fourth.
check for boost leaks (as has been said!)
Inane
Postby u4dina » Mon May 02, 2005 11:14 pm
I've got a caldina and nothing has really been done to it except the exhast system im finding what "fivebob" said that it does depend on the load...... at first gear i hit about 10pounds and from 4th to 5th i'm hit about 13pounds and 14 pounds max depending on how much load there is but that usually eases back quite fast to about 12 pounds again.....
1998 5spd Gt-T Caldina loving it...........
u4dina
