4AGE into KE70
4AGE into KE70
Postby >DOBES< » Mon May 02, 2005 7:33 pm
How hard is it to put a blue top 4AGE out of a AW11 into a KE70 SL?
Is it hard to convert to RWD?
What gearbox do u use?
How much work is it,can someone list the things to do to complete it?
>DOBES<
Postby Rick » Mon May 02, 2005 9:29 pm
Postby RS13 » Mon May 02, 2005 10:11 pm
Is Rob not going to put a 4K in it? I researched a 4AGE conversion for that car, you'd need an AE70 crossmember (with rack n pinion steering) which would bolt up, and a lot of TE71 bits and pieces, fuel lines, tank, pump, maybe a dash if you want a tach.. a lot of expensive, hard to find bits and pieces.
RS13
yeah
Postby side-wayz » Tue May 03, 2005 11:22 am
Yeah i just got the new 4k in,Just thinking in the not so distant future for more power..Any ideas of other engines?
side-wayz
Postby spencer » Tue May 03, 2005 12:20 pm
ae85/6 cross member fits fine into a ke70, you need a k50 or t50 gearbox from any A series rwd car and a matching gearbox x-member. mod the pedal box for the hydro clutch if you go T50. Efi stuff like fuel pump lines maybe surge tank and do some reseach into wireng it up. sort a driveshaft + some other stuff i cant remember and your away. Best way is to collect the stuff over time so you dont end up with a half finished project
ms63 crown
spencer
Users browsing this forum: Google [Bot] and 2 guests
