VVT Pulley
VVT Pulley
Postby 20v FX-GT » Wed Mar 24, 2004 10:16 am
Has anyone had any problems with their VVT pulley? Rattling on startup etc? Anyone know if the VVT pulley is the same on the silvertop as the blacktop? Anyone able to check EPC?
Thanks
1981 & 1982 MK1 VW Golf GTI 8v
1997 AE111 Toyota Trueno 6 Speed
My profile l AE101 FX GT Site l AE111 BZ Site l
20v FX-GT
Postby Mr Revhead » Wed Mar 24, 2004 11:53 am
they are different. its reasonably common for the damping fliud to leak out making them rattle, apparantly this doesnt cause any problems except the noise. can sell you a new one if you want but first youll have to tell me if you gotta black top or silver!
Postby 20v FX-GT » Wed Mar 24, 2004 1:11 pm
Its for a silvertop - is a blacktop one compatible / better / worth getting instead? Do they both alter the timing to the same extent?
What do they cost Mr Revhead?
20v FX-GT
Postby Mr Revhead » Wed Mar 24, 2004 2:02 pm
no they will not be compatible, the vvt systems are different can do a new one for $320 inc gst and freight normal retail $922!!
Postby 20v FX-GT » Wed Mar 24, 2004 2:16 pm
Thanks Mr Revhead, that price isn't too bad - especially when you consider the retail price 8O . I'll let you know :D
20v FX-GT
Postby Mr Revhead » Wed Mar 24, 2004 2:18 pm
hehe yeah we aim to shock i mean please :lol:
Postby 20v FX-GT » Wed Mar 24, 2004 2:31 pm
So if the VVT system and pulley are different for blacktop and silvertop how do people get on with blacktops in AE101s?
20v FX-GT
Postby Mr Revhead » Wed Mar 24, 2004 2:33 pm
? they run the complete engine and ecu.....
Postby 20v FX-GT » Wed Mar 24, 2004 2:37 pm
I'm pretty sure someone on here is running a blacktop with AFM, just curious to see how it works together.
Does the pulley have to come from Japan or are they in stock?
20v FX-GT
Postby Mr Revhead » Wed Mar 24, 2004 2:39 pm
black top with afm?? why?? ae101 pullys in stock ae111 ex japan
Postby 10k 20v » Thu Mar 25, 2004 8:23 pm
offensive's car came into country with blacktop and 6 speed running afm and silver loom and comp
10k 20v
Postby Loudtoy » Thu Mar 25, 2004 8:28 pm
20v FX-GT wrote:Its for a silvertop - is a blacktop one compatible / better / worth getting instead? Do they both alter the timing to the same extent?
Dude i got a spare one sitting in the garge i told penny about it last night but thats sweet -i'l give it to you for $50 and you can get someone to put it on and if doesn't cure the problem it won't cost ya a cent :) but if you find that it's the shims or something else it will still cost ya the $50!
Just quickly i bet thats the cheapest offer you've had so far?? 8)
TS Member sine 2001
Prado To tow stuff with
Rodeo to do work stuff in
Loudtoy
Postby 20v FX-GT » Thu Mar 25, 2004 9:52 pm
Thanks for the offer dude :D
I'm going to take the car down to the workshop and see if I can tell exactly where the noise is coming from with one of those stethoscope type things and also check out if it is a warranty claim. If I'm sure its the pully and not the shims we will most probably buy your one and get it sorted. :D
Wouldn't mind having a look at your pulley either way though.
20v FX-GT
Postby 10k 20v » Fri Mar 26, 2004 7:37 pm
You can just earth out the vvt soleniod and if the noise changes or goes away then it's your vvt pulley. The cheapest and quickest way.
10k 20v
Postby Xavier » Sun May 01, 2005 12:33 am
Mr Revhead wrote:they are different. its reasonably common for the damping fliud to leak out making them rattle, apparantly this doesnt cause any problems except the noise. can sell you a new one if you want but first youll have to tell me if you gotta black top or silver!
so is it vvt cam problem if the engine make noise when rev around 1200 - 1600 rpm... my AE111 engine got noise when start cold as the rev goes up to 1400rpm and come down after a while when the engine is warm...
Xavier
Postby CozmoNz » Sun May 01, 2005 9:38 am
generally youll hear the noise at idle.... tick tick tick tick tick, not to exessive, but there.
above those revs usually you dont hear it for its lovly whine >.> and i still cant *hear* a tick when i gun it... then again, everything is noisy X_X.
just install a vvt light ;) when dosnt turn off, its time to replace the vvt light :D.
Rayne For President!
CozmoNz
Postby Xavier » Sun May 01, 2005 1:40 pm
hmm... sometime i do hear it when idle, sometime it doesn't... perhap i need a mechanic to have a look... anyone know any good mechanic that can solve my misery?? :D
Xavier
Postby matt dunn » Sun May 01, 2005 10:07 pm
20v FX-GT wrote:So if the VVT system and pulley are different for blacktop and silvertop how do people get on with blacktops in AE101s?
What I think you'll find is the the VVT pulley is matched to the cam.
Blacktop pulley with Blacktop cam,
Silvertop pulley with Silvertop cam.
They may have different locators etc.
matt
Postby 10k 20v » Mon May 02, 2005 9:47 pm
it's just the location of the dowl pin, 5 degrees different but cant remember which way
10k 20v
Postby sergei » Mon May 02, 2005 11:42 pm
I run Black Top Cams with Black Top Pulleys on silver top, no noticable difference in VVT functionality.... infact feels the same, the only difference, I THINK, is that it pulls slighty better after 8000rpms till 9000rpm (limiter) with black top camshaft... but at those rpm VVT is off anyway...
