More power from 96 Supra Sz...
Postby SupraSz » Wed Apr 27, 2005 10:34 pm
I have had a search through the forums but can't find that much about getting more power from a NA Supra.
I have an aftermarket exhaust system and will do the intake as the next step but what would it take to get the car into either the high 13's 1/4 mile or low 14's...
I have sort of brushed on the idea of NOS. I was looking at maybe a 100hp NOS shot.
Can someone please provide me with more information on this.
Thanks...
SupraSz
Postby deaf_rattle » Wed Apr 27, 2005 11:42 pm
you might be better off joining up to the mailing list on
www.supras.org.nz
someone there will be able to point you in the right direction
Postby SupraSz » Wed May 04, 2005 7:13 pm
Have joint up now but unfortunately still no luck really...Will try the USA Supra forums since they are still pretty big over there...
Thanks anyway
SupraSz
Postby Si » Wed May 04, 2005 7:47 pm
Is it auto or manual?
Not to sure myself of the NA potential of one of those, not many parts availble for them for NA performance (aftermarket camshafts etc are all turbo suited)
Just boost it :lol: 8)
Current: , '96 SubaruImpreza
Si
Postby FST4RD » Wed May 04, 2005 8:16 pm
I second the boosting idea!!!
1983 Mitsubishi Starion
1995 Subaru legacy GT SW
FST4RD
Postby flygt4 » Wed May 04, 2005 8:34 pm
cheapest way is nos :wink:
flygt4
Postby Lunchie » Thu May 05, 2005 8:58 am
flygt4 wrote:cheapest way is nos :wink:
thats a pretty good idea... a 75hp nos shot would cost bout 1000-1200 installed and your engine would handle it fine and nothing else would even come close in terms of bang for buck mods...
"The air is heavy with antisipation as cozmo revs, drops the clutch and...... stalls with the hand brake on"........ "cozmo's hand brake one, cozmo 0"
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1201 <----Click to see real POWER :P
Lunchie
Postby Adamal » Thu May 05, 2005 9:23 am
NOS? Bang for buck?
Don't forget: Mods = Money / power / time!
If you consider that NOS will typically only last for a minute (if you run it flat out), that seems like a bit of a waste of money for the power of the mod!
Get some REAL mods that will give your engine REAL power! Such as cams and headword! :D
Postby Si » Thu May 05, 2005 7:26 pm
And then what, 100$ a tank every month or so,
thats about $2400.
You could get a 1jz engine for half that, swap the head pistons etc, buy new rods and have a nice flash 1.5jzgte :) use the 1jz ecu with a 2j map sensor and injectors, and you now have one quick whale :)
Si
Postby Lunchie » Thu May 05, 2005 8:29 pm
thats about $2400.
i stand corrected
Lunchie
