VVT Light ---> MORE HELP PLZ
Postby BZR4AGE » Thu May 05, 2005 2:34 am
hello guys, i have done some research and also on this forum.
i have found the clearest directions, tht is: (but there is a part i dun understand)
Connect the Negative side of the LED to the VVT output on the ECU's 26 pin connector. This will switch to Gnd when VVT is activated, causing the LED to turn on.
on a black top ECU diagram, there is actually a code called VVT. which is not on the 26pin. can anyone tell me which exact one am i suppose to connect to? below is a ECU diagram for the blacktop 20V.
and also, someone mention to put a diode on the LED so tht it will not send signals to the ECU. is tht the small black one with a silver band at one side??
thx for any help guys
BZR4AGE
Postby sergei » Thu May 05, 2005 9:36 am
Connect negative of LED to VVT and positive to +B, also don't forget resistor...
and there is no need any diodes for many reasons (first: LED is a DIODE, and second VVT output is a transistor output - hence its not an input)
VVT <----vvvv-----|<|---------> +B
___resistor ^__LED ^
resistor can be anything from 500 Ohm to a few KOhms, depends on your LED and how bright you want it
Postby BZR4AGE » Thu May 05, 2005 10:39 am
thx alot for the quick reply, will try this week end~~~ hope it works! cheers again
BZR4AGE
Postby Xavier » Tue Aug 02, 2005 10:27 pm
how is the VVT light going BZR4AGE?
did it works?
and sergei, the lower the ohm for the resistor, the brighter the LED or opposite....
i thought of doin it on my spare time... :D
is there any thing i need to watch out 8O
Cheers...
My Profile
1999 Altezza AS200 Z
1995 Trueno BZG (Previous)
1992 MR2 GTS (Previous)
Xavier
Postby Mr Revhead » Tue Aug 02, 2005 10:53 pm
arrrgh i hate electricks.
couldnt you just connect a light to the negitive side of the solenoid?
Postby Xavier » Tue Aug 02, 2005 11:53 pm
Mr Revhead wrote:arrrgh i hate electricks.
can i? how do i do that???
Cheers...
My Profile
Xavier
Postby BZR4AGE » Wed Aug 03, 2005 3:07 am
hahahah, i ended up not trying coz i got some toda cams and can't use VVT with it.
BZR4AGE
Postby Mr Revhead » Wed Aug 03, 2005 9:22 am
i dunno, thats why im asking.....
actually youd want to find which side its switched... then hook in to it after there..... so when power is applied to the solenoid, its also applied to the light
Postby Xavier » Wed Aug 03, 2005 12:19 pm
BZR4AGE wrote:hahahah, i ended up not trying coz i got some toda cams and can't use VVT with it.
nice, so u get higher rev with toda cams? how much horsepower did u gain? i guess it cost a bomb to get it install... 8)
Cheers...
My Profile
Xavier
Postby BZR4AGE » Wed Aug 03, 2005 3:13 pm
Not fitted the cams yet. i am saving up big $$ to do the whole engine, as now i have imported from japan a full toda engine kit for my car
And to be honest, importing from japan is much more cheaper than buying from a dealer from here. here you would expect to pay over $4000 for the kit, but i got it for 3/4 the price of it. So now i am officially broke. But can't wait till i fit all of those in there. i am expecting at least 200hp at the flywheel.
Then i will be the King of 1.6L NA. MUhhAHHAHAhaHHAHAHAHHA. (in my dreams)
Now all i am waiting for is finish saving up for a full engine rebuild with these items.
BZR4AGE
Postby Mr Revhead » Wed Aug 03, 2005 3:17 pm
a FULL toda kit for how much? um are you sure?
so thatsl be pistons and cams etc etc
Postby AceSniper » Wed Aug 03, 2005 3:52 pm
also what specs did you get the kit as... aka cam lift duration, compretion ratio, oversized pistons? ... list goes on
AceSniper
Postby MrOizo » Wed Aug 03, 2005 4:14 pm
is it going to look like this? :o
bling!
MrOizo
Toyspeed Legend
Postby mr pad » Wed Aug 03, 2005 5:56 pm
Mmmmm nice. Thats a 16 valve though, do they make a 20v like that? No? Is that cause 16v's are better? Ok. *Finishes talking to self*
mr pad
Postby ChaosAD » Wed Aug 03, 2005 6:52 pm
Toda is pretty reasonably priced now.
Cams are about $899 for a pair.
I think the kit has cams, pistons and ecu.
ChaosAD
Postby BZR4AGE » Wed Aug 03, 2005 7:34 pm
heres my kit
1) 11.8 compression 82mm forged piston kit
2) 272 intake 9mm camshaft
3) 264 exhaust 9mm camshaft
4) uprated valve springs
5) In and Ex Cam gears
Got it all for $3000NZD +GST = around $3400NZD. I have connection in japan, thats why i can get it for so cheap, but only for myself (good mate prices)
BZR4AGE
Postby BZR4AGE » Wed Aug 03, 2005 7:36 pm
Heres the stuff :twisted:
BZR4AGE
Postby Mr Revhead » Wed Aug 03, 2005 8:37 pm
so whats in the kit?
cams
pistons
vernier cam pulleys
valve springs
does it come with retaniers and collets etc? bearings? headgasket?
what compression are the pistons?
$3k is more realistic.
looks liek a good kit, i have to admit, i thought u said 1/4 of the price....
Postby BZR4AGE » Wed Aug 03, 2005 8:46 pm
hey mr rev head.
check my post again
"but i got it for 3/4 the price of it"
HAHAHHA. i do wish i can get it 1//4 of the price.
nope~ i am going to get a TRD headgasket when i start the rebuild. they are same stuff as TODA, but TODA actually twice the price.
nope, does not include the retainers as well, but i am trying to get some brand new valves for my engine, as i would imagine my valves now will not be in perfect shape. wht retainers should i get too? or should i just get brand new genuine ones?
compression are 11.8:1
HAHAHA, this VVT thing turn into a TODA chat thing. quite intersting too.
I am hoping to build a strong 1.6L N/A car which will beat the 1.6L Civic Type R. Hope this kit will do well for me
:twisted: :twisted: :twisted:
heres my kit
BZR4AGE
Postby Mr Revhead » Wed Aug 03, 2005 9:08 pm
hmm very cool
send me an email with a list, and ill see what i can do.....
i assume your using ARP bolts etc?
theres a few options for retainers etc, your cams maybe a bit much for stock ones.... but talk to some engine builders about that. going past my expertise there!
