3k head on a 4k..opinions
Postby scope » Thu May 05, 2005 10:38 pm
hey
i've heard good and bad things about doing this but what is your opinion on it? i'm thinking about doing it but not gonna bother if it ain't worth it
chicken fillet and bacon with everything except onion and bbq, ranch and southwest sauces
current ride: 1980 mazda rx7 series 1
previous rides: ke36 corolla, series 1 rx7, ke30 corolla, ke70 corolla x2
scope
Postby Dell'Orto » Thu May 05, 2005 11:03 pm
Its the 3k-b head most people use...pushes compression up, which provided you can add fuel and adjust timing to suit, will result in a bit more power.
Postby fangsport » Thu May 05, 2005 11:18 pm
from memeory the 3kb head has the correct port sizing for side-draft manifolds as well.
fangsport
Postby matt dunn » Fri May 06, 2005 1:00 am
Mmm, Boost wrote:Its the 3k-b head most people use...pushes compression up, which provided you can add fuel and adjust timing to suit, will result in a bit more power.
I rebuilt my 4k Corolla with std 4k pistons and the 3KB head.
Was a real good car to drive. Heaps more than a normal 4K.
Dont know if it was because it was a 3k head or if it was because it was the bigport 3KB.
Matt
Postby THA SHZ » Fri May 06, 2005 9:12 am
and the 3kb head comes out standard with twin carbs so is easily matched for twin sideys . this is wot i had done on my dx and chucked in a wild cam and it went really well , was a fun car until i needed more power :twisted:
THA SHZ
Postby ke_25 » Fri May 06, 2005 11:42 am
yes the 3kb head has larger ports in it. but i cant remeber wether the normal 3k-u head was beter over the 3kb head or not?...
PRESENT: KE35 Sr coupe (4agte project), GTS-T, MX40 Cressida coupe
EX:KE25 SL Coupe, KE30 4 door, KP61 4 door hatch, KE36 2 Door Wagon, AE70 2 Door Sedan, AE101 FXGT
ke_25
Postby scope » Fri May 06, 2005 11:51 am
yea i have a 3k-u lying around, not a 3k-b :(
scope
