105kph Bling Bling!
105kph Bling Bling!
Postby blackmk3 » Sat May 07, 2005 7:31 pm
at 105kph the little bling blinge speaker goes....u know the 1s :?
how do i get rid of it? were the speaker?
Mk3 MA70 Supra
blackmk3
Postby ee904age » Sat May 07, 2005 7:35 pm
What car? Could be behind the speedo, in the steering column, under the dash, in the pedal box.......the list goes on
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby blackmk3 » Sat May 07, 2005 7:55 pm
1989 7mgte mark 3 supra, digital dash
Mk3 MA70 Supra
blackmk3
Postby Malcolm » Sat May 07, 2005 8:22 pm
on all car's I've removed it from, it's been behind the instrument cluster, it's a silver box with a little yellow (normally) wire going to it. Just cut the wire or completely remove the box
Postby blackmk3 » Sat May 07, 2005 8:32 pm
instrument cluster being handbeak light seatbelt light etc? bottom center of the dash
Mk3 MA70 Supra
blackmk3
Postby blackmk3 » Sun May 08, 2005 9:03 pm
ar?
Mk3 MA70 Supra
blackmk3
Postby AceSniper » Sun May 08, 2005 11:25 pm
on mk3 they are on the back of the dash just remove the dash and a little metal box will be attached remove it....
AceSniper
Postby blackmk3 » Mon May 09, 2005 7:33 pm
so i pull the entire dash out of the car?
Mk3 MA70 Supra
blackmk3
Postby Malcolm » Mon May 09, 2005 10:02 pm
instrument cluster is the whole big plastic thing which houses all the gauges, the lights you mentioned, and a couple of air vents on a mk3 supra
Postby the fallen303 » Mon May 09, 2005 11:28 pm
on the analog dash, it is a box just attached to the back of the instrument cluster, that all fours discribed. has two wires to it i think, one of them even goes to a screw on the back that says dinger, or chime. just undo, and remove. not sure about the digital dash, have not managed to find it on any of my 4 that i have, but they could have been removed.
true house of JZ
Stay true to the origin
the fallen303
Postby blackmk3 » Tue May 10, 2005 9:08 pm
hmm oh well this weekends task
Mk3 MA70 Supra
blackmk3
