GT-T oil choice
GT-T oil choice
Postby Santa'sBoostinSleigh » Mon May 09, 2005 12:44 pm
Howdy there - coming up to oil change time again and i was just wondering what oil you other GT-T owners run? and what is recommended.
Andrew
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby beerad » Mon May 09, 2005 3:30 pm
sorry to hijack the post, but also need to know, aswell as what spark plugs and other things to replace on a major service. cheers
beerad
Postby GT4 20 » Mon May 09, 2005 3:36 pm
I use Castrol RS 10w 60 in my GT-FOUR's 3S-GTE.
Gary
1999 Subaru Legacy B4 RSK TT
GT4 20
Postby CozmoNz » Mon May 09, 2005 3:44 pm
Penrite 5w 60, Gen 4 Mr2 3sgte.
Rayne For President!
CozmoNz
Postby Wildcard » Mon May 09, 2005 3:47 pm
CozmoNz wrote:Penrite 5w 60, Gen 4 Mr2 3sgte.
3rd Gen 3SGTE :P
Wildcard
Toyspeed Founder
Postby CozmoNz » Mon May 09, 2005 3:50 pm
Nup, 3rd gen = indicator on bumper
4th gen = indicator behind wheel / on guard.
also has 10th anniversary door sill trim :D. (chrome) with MR2 written on it >D
/feels special
CozmoNz
Postby Mr Revhead » Mon May 09, 2005 3:53 pm
plugs: denso pk20r8
Postby blitza » Mon May 09, 2005 5:28 pm
royal Purple 10-30, its purple! plus fram filter, as they are so small you dont want any old shit filter.
MAD Industries Limited
'97 GTT auto, -under rebuild, again.
the faster you go, the quicker you get there...
blitza
Postby Mr Revhead » Mon May 09, 2005 5:31 pm
genuine filters are best, we used to stock fram, but got sick of the leaks!
i think they have improved, but take a bit to beat a stock filter
Postby snwtoy » Mon May 09, 2005 6:03 pm
I've used Castrol magnatec in all the turbo cars I've had. Not sure what the workshop uses when it goes for a service, but it'll be whatever's recommended I guess.
snwtoy
Postby fuel » Mon May 09, 2005 8:23 pm
To the guys using 5W60 and 10W60.. why so thick oil? Remember the 5 and 10 value is how thick (or thin) it will be at startup, and the 60 is what it will be at optimum operating temp. I was under the impression a 60 grade is way to thick for a multi valve, twin cam, and turbo vehicle, especially one which revs up high.
I would be using something like a 10W40, and something decent. The Castrol RS 5W30 is a good oil.
LOUD NOISES!!!
fuel
Postby ee904age » Mon May 09, 2005 8:41 pm
fuel wrote:To the guys using 5W60 and 10W60.. why so thick oil? Remember the 5 and 10 value is how thick (or thin) it will be at startup, and the 60 is what it will be at optimum operating temp
Ummmm, isnt it the other way round??? Oil gets thinner as it gets hotter
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby Hachiroku » Mon May 09, 2005 9:24 pm
Yep but I'm fairly sure the two numbers are independant of one another. ie 10w30 doesen't mean its 3 times thicker when its hot than when its cold. Fuel is right: 1st number is cold viscosity, 2nd is hot viscosity.
Hachiroku
Postby Wildcard » Mon May 09, 2005 10:57 pm
CozmoNz wrote:Nup, 3rd gen = indicator on bumper
/feels special
Yes I know - I have one :)
What I mean is that the engine you have is the Gen3 3SGTE, not the Gen4 like the Caldina, just clearing that up in case anyone else was confused ;)
Wildcard
Toyspeed Founder
Postby snwtoy » Mon May 09, 2005 11:05 pm
A 10W-50 is a 10 weight oil when cold, that will thin no more than a 50 weight would when hot.. go twist your head around that one hehe
I was always under the impression that the thinner an oil gets, the less it's lubricating properties are..
snwtoy
Postby sergei » Mon May 09, 2005 11:22 pm
the thinner oil the less stress it can handle, less protection it can provide
Castrol 10w60 I think is the very good oil for highly stressed cars,
I used it for many years (before it was called Castrol Formula RS), in my 20v which sees 9000rpm on daily basis, can't complain, it lasts longer than anything else (for example while 10w60 lasted about 7500kms without need of top up, the Mobil 1 5w40(?) did not even lasted 3000kms on same engine),
the fact that the oil becomes thicker is that it is a multigrade oil, and yes it can be compared to 60 grade "normal" oil when hot, and numbers represent not how heavy it is but viscosity...
Postby fuel » Tue May 10, 2005 8:22 pm
Interesting. I see all you guys have valid points, but I was just under the impression the higher the number - the thicker it is. Sure this may be great for lubrication, it may not be as good for a multi valve engine which revs up high. A thinner oil has less friction for the engine to overcome, compared to a thicker oil. This would translate into increased fuel consumption and heat with a thicker oil (theoretically). This is what the Pennzoil rep guy said to me. He could be wrong.. he only sells the stuff, not develops it.
All I know, is that my fuel consumption increased and the engine didn't like to rev much when I switched to a good 20W50 over a good 15W40. I made the switch because being a mitsi, it consumes oil like it's going out of fasion.
LOUD NOISES!!!
fuel
Postby Rob » Tue May 10, 2005 8:44 pm
The higher the second number the thinner it is and the easier it flows around the engine for better lubrication. If you have a car with high K's such 285000 like my corona then use a thicker oil such as 20W50 or 20W40 as it won't go round the rings as easy as an oil with less viscosity
1990 ST185H - project
1996 VS Acclaim wagon
Rob
Postby fuel » Tue May 10, 2005 9:56 pm
Uhmm, the higher the second number, the THICKER it is dude.
20W50 is definitely thicker than 20W40.
10W40 and 15W40 has better cold starting properties over 20W40.
LOUD NOISES!!!
fuel
Postby RunningRich » Wed May 11, 2005 11:09 am
All these statements, yet not a single person has yet mentioned API catagory...
Richard
http://gtfour.supras.org.nz
RunningRich
