Chaser mods
Chaser mods
Postby chaser » Wed May 11, 2005 10:18 pm
Anyone know if the LSD 4 pot brakes off a turbo auto(diff ratios) JZA80 supra will bolt on to a 97 JZX100 Chaser Tourer S?
chaser
Postby chaser » Wed May 11, 2005 10:19 pm
I mean LSD and/or 4 pot brakes! :roll:
chaser
Postby TRD Man » Wed May 11, 2005 10:45 pm
The diff is different & I suspect the brakes are also.
TRD Man
Postby Malcolm » Wed May 11, 2005 11:21 pm
i've seen a documented swap of the supra 4 pots onto a jzz30 soarer and from memory it was pretty much a bolt on swap
Postby TRD Man » Wed May 11, 2005 11:46 pm
Soarer & Supra do share many parts. Chaser is different.
TRD Man
Postby edwagon » Thu May 12, 2005 9:40 am
I might know where there is a mint Torsen lsd for a chaser 8)
but as TRD man has said, supra/soarer are similar but chaser is different.
edwagon
Postby suberimakuri » Thu May 12, 2005 10:24 pm
Diff wise: JZX90 & JZX100 will swap with each other only (as long as 6 bolt CV hubs on diff), not with supra/soarer tho etc as recently found out totally different.
Brakes: yes JZA80 rotors and calipers will bolt straight onto JZX90/100 series. Have bolted to my JZX90 before & my friends JZX100 is currently running at the moment.
Have both available if required too...($650 exchange torsen diff/$600 4pots & rotors)
Hope this helps, have fun :D
suberimakuri
