Dot 5.1
Dot 5.1
Postby Dell'Orto » Thu May 12, 2005 10:51 pm
Now, shortly I'll be doing my brake system, and I want to use dot 5.1 brake fluid.
What hassles are there, and are there any special procedures needed to run dot 5.1 after previously using dot 4?
Postby Adamal » Thu May 12, 2005 10:54 pm
As far as I know, all new DOT ratings that come out and 'compatable' with systems that use the previous rating.
They typically say "Use at least DOTX"
Much like oil!
Postby Lloyd » Thu May 12, 2005 11:05 pm
But 5.1 is different. Why exactly do you want to use it? Its pretty much for race applications and thats about it.
Postby Malcolm » Thu May 12, 2005 11:15 pm
yeah, there is very little reason to switch to 5.1 on a street car unless you want to be completely flushing the system annually
Postby 85AW20v » Thu May 12, 2005 11:24 pm
Have alook in FAQ - the post at the bottom of the list - all about brakes, fluids etc. Explains it all very simply.
See ya
Simon
85 MR2 20v
85AW20v
Postby Dell'Orto » Thu May 12, 2005 11:40 pm
Its not for the KE70 by any means :lol:
Postby pc » Fri May 13, 2005 9:22 am
Should be no problems using dot 5.1 I'm assuming you will be using synthetic and not silicon fluid.
The fluid just costs a bit more. Other than that, you probably wont notice any difference over dot 4.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby Dell'Orto » Fri May 13, 2005 11:53 am
Thing is, I do intend to give my car a bit of a burn round Manfeild once completed, maybe a few times even ;) I'd like something that isnt going to boil itself into nothingness after 6 laps.
I figure heavyish car with a fair bit of power, its gonna get the brakes hot.
Still undecided as to which pads to use too, kinda leaning towards EBC green stuff.
Postby wde_bdy » Fri May 13, 2005 12:15 pm
Race Brakes have what you need, ELF’s XT3167 . Their site also has a very detailed explanation of all the different fluid levels and other brake options. May be the same as whats in the FAQ from memory.
http://www.0800brakes.co.nz/
Have a chat to them about Mintex pads too.
Callum
wde_bdy
Postby vvega » Fri May 13, 2005 2:58 pm
5.1 is compatable with your exsiting fuilids
its not a silicon based fluid and dose not need to be flushed yearly
the most important aspect of 5.1 is it boiling point helping to reduce fade
:S
v
vvega
Postby TygerTung » Fri May 13, 2005 3:33 pm
The problem with 5.1, is that it doesn't absorb moisture.
All braking systems produce moisture, and since it's not abosorbed, you'll just have a bit of water in there. This will boil very easily, so then you'll just get bad brake fade.
I'd recomend a good racing dot 4 fluid.
You can get Motul factory line Racing brake fluid for a decent price.
TygerTung
Postby pc » Fri May 13, 2005 5:21 pm
Only if it's silicone based, as it's not, then it will absorb the moisture. dot 5.1 has a slightly higher boiling point than dot 4 so in theory it will be better.
I personally think all brake fluids should be flushed yearly, but that's just personal preference.
red car
Manfield - 1:24s
pc
Postby wde_bdy » Fri May 13, 2005 6:10 pm
TygerTung wrote:The problem with 5.1, is that it doesn't absorb moisture.
You are confused with DOT 5, which is silicone based. DOT 5.1 is generally for synthetic (not silicone) fluids and is the highest rating available.
Callum
wde_bdy
Postby vvega » Fri May 13, 2005 6:20 pm
100% correct
but in saying that i belive the silicone based product is still better
5.1 is great fuild used it in my bikes for years with much hard abuse cabt rate it highly enough
and yes 5.1 is hydroscopic
braking systems dont produce mositure they absorb it...hence hydroscopic.........
anywasy back to the mindless babble
vvega
Postby Dell'Orto » Fri May 13, 2005 6:29 pm
vvega wrote:but in saying that i belive the silicone based product is still better
Why is that? I was lead to believe it makes the pedal kinda spongy due to the compressability of the fluid?
Postby Truenotch » Fri May 13, 2005 6:43 pm
Brad never use silicone brake fluid!!! Have a look on the ebc site theres some stuff about what yoou should and shouldn't use, silicone fluids is not supposed to be used because when the brakes get hot the water produced gets trapped and makes the padal do nought.
Truenotch
Postby Truenotch » Fri May 13, 2005 6:54 pm
http://www.0800brakes.co.nz/pg8.htm
Looks like dot 5.1 would be sweet.
Truenotch
Postby vvega » Fri May 13, 2005 9:10 pm
from my understanding silicon fuild is spose to be changed on a per meeting basis
silicon also ahs a trumendously high boiling point ...obviously dependant on what you buy as per anything
you also cant mix the 2 fuilids tends to turn to stringy slimmy stuff :D
v
vvega
Postby Perky » Tue May 17, 2005 6:03 pm
Exactly. 5.1 was obviously a bloody stupid name to use since it always causes this confusion. I take it that the DOT numbers were originally intended to specify the fluid's characteristics rather than its composition -- but then they were also supposed to guarantee compatibility :roll: . Presumably this is why some brands, such as Castrol, market a Super DOT 4, which they recommend for applications requiring DOT 5.1. The DOT boiling points are actually minimum values, so a DOT 4 can have the same or higher boiling points as DOT 5.1. I use DOT 5.1 because it is also supposed to be a bit thinner and more suitable for ABS equipped systems, but I doubt that anyone has ever had a problem using DOT 4.
Perky
Postby dimmy » Wed May 18, 2005 3:29 pm
i can't remember the exact reason but once you go to dot 5.1 you can't go back to dot 4, i'm 97% sure of this. :)
dimmy
