BZ-G wrote:But money wise…. Is not cheap… plus you have to service it every 10,000km… ship back to Japan to get it service too…
It’s basically a racing suspension…….
TRDWGN wrote:The magic part of the equation that people do not seem to understand, quality coilovers are designed to be serviced regularly and unless you can get it done locally then it becomes a highly expensive exercise...
I had coilovers in my carib and have swapped them out because they are simply too harsh and noisy for a daily driver due to lack of insulation when compared to standard style shocks, I now have bilstein inserts in standard toyota strut housings which have been valved and shortened to suit my requirement and Tein S tech medium springs, the end result is a ride that has 98% of the control and handling of the coilover set-up but with NVH that are similar to standard, this IMHO is a perfect set-up for street/daily driving, if you are going to be racing get coilovers otherwise it is a waste of money for the street
phatman3801 wrote:if price isnt a problem wot would b the best brand of coilovers to get for a ae111 levin non superstrut? is trd the best??
BZ-G wrote:Ok TRDWGN… I bowel to you…you are the guy to talk to regarding coilovers… I just gave an opinion on coilovers… I guess you will be the guy to talk to for street coilovers specialist… you can do all the explainations…
TRDWGN wrote:Another (major) disadvantage I forgot to add to my list above is the effect a stiffly sprung setup has on factory ABS setup, i found my car used to pulse unnecessarily due to (I presume) an unloaded wheel so treated the situation much like it would ice or gravel, quite disconcerting when the pedal goes to the ground!! since putting the progressive Tein's in it seems to have eliminated this aspect... I checked out your site, that is a pretty impressive car you've got! all the right bits in all the right places, jsut out of curiousity have you considered repowering with 2ZZ-GE and TRD hi comp kit? good reliable 200+HP at a cost not too dissimilar to getting similar HP from the mighty blacktop
