2fas4u wrote:i got the autotechnica 100/90 watt ones in my "night vision" spotlights and fark they were lot better than my autotechnica 55/60w ones in my headlights set on high beam. they reflect off roadsigns like heavenand they shine for nearlly two blocks down the road
I've used the Hella Xenon (+50) bulbs. They're junk.
I've used Narva Artic blues. They're junk.
I've used the Hella Xenon Ultra (blue ring). They're okay.
The cool blues are good. Better apparant output that their Xenon cousins, and they reflect off street signs a LOT better.
Perky wrote:I don't think it is very helpful to write these bulbs off as junk. Your personal experience on the other hand is a useful contribution. I'm interested that you prefer the Cool Blues -- maybe there is something to the claims about our perception of higher colour temperatures (sorry, I said 'lower' in my earlier post: blue/white is higher temp. than standard).
The Cool Blues are actually dimmer than standard bulbs (Hella describes their output as "similar" to standard!). I suspect the Narva Arctic (sic) Blues are also dimmer, despite Narva's ambiguous claims. The Xenon bulbs you mention are brighter than standard.
The thing to note is that the higher colour temperature of the blue/white bulbs is achieved by filtering out the lower colour temperatures, so there is less light overall. Another reason to be sceptical of these bulbs is that the marketing niche they were created to fill is based on cosmetic considerations -- not least being their resemblance to expensive HID lighting. Yet another reason for scepticism, in Narva's case anyway, is that they also market low colour temperature bulbs for driving in poor weather, based on demonstrably false physics.
The Hella Xenon Ultra bulbs are available in New Zealand. I'm pretty sure the ones I have seen are made by Phillips, which is odd since the Phillips-associated Narva ones aren't. In any case, you can buy the same bulbs in Phillips packaging.
matt dunn wrote:My advice,
Fit a wiring kit,
fit Hella 100/90w bulbs,
and get them adjusted by someone with a beamsetter that has degree settings on it.
Keep the lenses clean
Matt
JT wrote:matt dunn wrote:My advice,
Fit a wiring kit,
Matt
I took a good look at the wiring and it turns out someone has re-wired the front lights with good wire and a set of bosch relays. Maybe you did the wiring on my car as it was formerly from the south. I possibly had the dip down too far with the old bulbs in but one of them blew so it was a good excuse to investigate better options.
I got some 100/90 bulbs and everything is so much brighter! Street signs and number plates light up from so much further away and on full beam I reckon I could take it possum hunting, who needs spotlights! I'll check the level again tonight but didn't get one person flashing their lights back.
