AA Inspection Qs
AA Inspection Qs
Postby Myko » Thu May 19, 2005 12:38 am
i'm buyin an 1996 Levin BZG, i've got the AA to check for me and dey said dat it hesitates on acceleration, wat does dat realli mean?
Myko
Postby RS13 » Thu May 19, 2005 12:41 am
I wouldn't buy it if the AA inspectors didn't know what was wrong! It means you'll be paying lots of money to other people to find out what the problem is..
RS13
Postby Wildcard » Thu May 19, 2005 12:45 am
Many things can cause this, however the most common is worn ignition components, these are a 'disposable' item on any car. Expect to pay about $200-300 to replace the majority of the ignition components...
Wildcard
Toyspeed Founder
Postby Dell'Orto » Thu May 19, 2005 12:48 am
Depends, I know of a few blacktop 4AGE's that have a hesitation around the 3 grand mark, and nothing short of unplugging the VVT seems to stop it.
Postby Myko » Thu May 19, 2005 12:56 am
Wildcard wrote:Many things can cause this, however the most common is worn ignition components, these are a 'disposable' item on any car. Expect to pay about $200-300 to replace the majority of the ignition components...
so where shuld i go to to check up wats wrong wif it, i'm payin 7 grand for this car atm
And also wats a sign for this problem, i couldnt notice anything -_-"
Myko
Postby NZ_AE86 » Thu May 19, 2005 8:15 am
Tell the yard your buying from (assuming it is a yard?) that the condition of purchase is to have this fault repaired. But I have also seen a few blacktop's with a hesitation around 3-3500rpm so it could just be a feature not a fault.
Also the AA would not know shit from clay. They are the most over-rated people when it comes to vehicle inspections and repairs. :P
NZ_AE86
Postby Mr Revhead » Thu May 19, 2005 11:22 am
the aa wont actually look into a fault, they just report symptoms.
a hesitation there on any 20v is normal when cold. also if its off a yard, its prob running 91 which will cause it to run like poos
Postby HZRDIZ » Thu May 19, 2005 12:33 pm
Mr Revhead wrote:the aa wont actually look into a fault, they just report symptoms.
Yeh i can vouch for this. My uncle put 91 in my BZG when he was borrowing it and it ran like a crock of shit. No acceleration, idled real funny - it just didnt like it... even better if you can run it on 98.
Also there is no torque down low (well i found anyway) so this may be what the slight hesitation is...
Drinking 42 BELOW Passionfruit Vodka is like walking along the street and seeing this really hot girl and all you can think is "Man, I don't understand how anyone can be gay".
HZRDIZ
