stuck on installing short sifter on my ae111 levin!
Postby phatman3801 » Thu May 19, 2005 3:52 pm
hey ive decided to put a short shifter in my levin...i took all the plastic suorndings away from the gear shifer, i then discontected both gear selectors but i dont no how to get the shifter out! the ball the shifter moves on is still stuck in the plastic cup! how bouts do i get it out???
phatman3801
Postby Mr Revhead » Thu May 19, 2005 4:00 pm
if i understand that right..... it just pops out.... more force required...
you mean the ball of the shifter is still in the plastic cradle that bolts to the pedastal?
Postby phatman3801 » Thu May 19, 2005 4:20 pm
im talking about the ball approx half way down the shifter the bigest one!
phatman3801
Postby Mr Revhead » Thu May 19, 2005 4:35 pm
yes, its still in the plastic cradle? use more grunt... it pops out
Postby phatman3801 » Thu May 19, 2005 4:45 pm
dose it pop out upwards like i pull, or downwards (push)??
phatman3801
Postby Mr Revhead » Thu May 19, 2005 4:55 pm
up
Postby phatman3801 » Thu May 19, 2005 5:04 pm
are u sure it just pops out? i pulled that thing as hard as i could many many times and it wont go!!!
phatman3801
Postby phatman3801 » Thu May 19, 2005 5:18 pm
there are to pins going through the plitsic over that ig ball, do those pins have to come out?
phatman3801
Postby Mr Revhead » Thu May 19, 2005 5:19 pm
theres slots in it..... try seperating them.....
Postby Mr Revhead » Thu May 19, 2005 5:22 pm
pins in the cradle?? or do you mean the ones above and below the cradle?
your the one looking at it... surely you can see what needs to be done....
Postby THA SHZ » Thu May 19, 2005 5:50 pm
pull those pins out and then pull up dude , its not that hard man 8)
THA SHZ
Postby phatman3801 » Thu May 19, 2005 6:01 pm
i got one of the pins out but the other one wont come theres that stupid washer thing which is right hard up against the plastic..
phatman3801
Postby phatman3801 » Thu May 19, 2005 6:42 pm
any one how how to get those pins out?
phatman3801
Postby Bling » Thu May 19, 2005 8:08 pm
angle grinder will get ANYTHING out :wink:
Users browsing this forum: Bing [Bot] and 21 guests
