Which CV?
Which CV?
Postby ee904age » Fri May 20, 2005 7:50 pm
How do I tell which CV is Dodgy? Both boots are split and the noise isnt loud enough to tell which side it is. It only clicks when turning right if that helps.....
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby Lloyd » Fri May 20, 2005 11:05 pm
Turning right would mean that the right hand CV is on more of an angle (the right wheel turning through a tighter circle) and that'll be the noisy one.
Postby Akane » Fri May 20, 2005 11:22 pm
change the dodgey CV man, last thing you want is a CV sticking thru your firewall when your car's doing 100kph.
Postby ee904age » Fri May 20, 2005 11:31 pm
Yeah I've got the new Cv here, am doing it tomorrow, just dont want to change the wrong one!!! And Im also replacing the boot on the other side.
90 SW20 N/A - Sold
ee904age
Postby ee904age » Sat May 21, 2005 1:19 pm
Ok, just got back from doing the job.
HRT's theory added up so I took a chance and changed the R/H CV, but unfortunately its th L/H joint!!!
Sooo, for future reference, a click on R/H corners is the L/H CV.
90 SW20 N/A - Sold
ee904age
Postby Lloyd » Sat May 21, 2005 1:39 pm
Maybe they were both a bit buggered. You can usaully hear where its coming from anyway? Are you swapping them over or getting another new one?
Postby ee904age » Sat May 21, 2005 1:45 pm
Ill just get a new one, only $60, its not worth fcuking around with.
90 SW20 N/A - Sold
ee904age
