Silver top hesitating at around 4k
Postby nz_baddass » Mon May 23, 2005 6:52 pm
Hey all,
I have a manual 20v silvertop ae101 and it hesitates at around 4k when accelerating, i have changed plugs and air filter to k&n and platnum plugs, and has made the problem a little better, i was told by a engineer making up a bigbore exhaust for me that there is a lot of carbon deposits in the exhaust. I was wondering if any of you know what may be causing the problem, and whether the engine running rich could be doing this.
Thanks David[/b]
nz_baddass
Postby dazzag » Mon May 23, 2005 7:39 pm
carbon is unburnt fuel or incomplete combustion.it could be alot of things causin this. your timing could be out ... how many kms has your car done? the HT leads could need replacing or there could be a resistriction in the air intake system. clogged fuel filters can cause hesitatons at higher revs too
want a ae86, dont want to pay 8 grand for one
have to settle for my ae92
dazzag
Postby nz_baddass » Mon May 23, 2005 11:30 pm
thanks, i will check timing 2morow, and get back to you, any other info would be great
nz_baddass
Postby nz_baddass » Mon May 23, 2005 11:32 pm
how could i test the ht leads? just a ohms test? car has done 140000km
nz_baddass
Postby dazzag » Tue May 24, 2005 6:06 pm
remove the ht lead. set it on k ohms should be below about 15,000ohms wiggle them around when doing it too
dazzag
Postby CozmoNz » Tue May 24, 2005 7:28 pm
no more than 12,000o per 30cm if i remember correctly.
anyway, removed my silencer again today, and man, you should have seen the carbon behind the silencer X_X argh!
stupid blacktops.... Rich...lean....rich....lean....lean...
i need an AFC....
Rayne For President!
CozmoNz
Postby Lloyd » Tue May 24, 2005 10:45 pm
Around the 8k per foot of lead is usually about right but it depends on your leads. As long as they are all fairly close and generally get higher resistance whent he leads get longer then you should be fine.
Wiggle then as said above just to make sure the lead isn't broken inside.
