Help Needed, 4age rebuit, running allmost......
Postby XS1V » Tue May 24, 2005 8:12 pm
well i bought the car with the engine not running. Its a bluetop motor from an nz new ae82 fxgt. i have had the whole thing apart, cleaned it all, put in new piston rings and new bearings in the bottom end and everything was at spec according to the book. Put the head on with all new gaskets etc as you do and conected everything up and set timeing etc. Everything has been done following the manual and torqed accordingly
Made sure everything was good and gave it a whirr, all most starts but not quite, if you hold it at about half throttle it starts.... very roughly sounds like its dropping a cylinder and at higher revs, round 3k the valves make a lot of noise.
Do i need to get some head work done, resetting valves etc??
What else could be up??
All help appreciated
XS1V
Postby ChaosAD » Tue May 24, 2005 8:26 pm
cam timing right? Did you strip the head at all? (shims could be wrong if you did)
ChaosAD
Postby ee904age » Tue May 24, 2005 8:29 pm
Yeah, sounds like cam or ignition timing. Did you have the dizzy out???
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby XS1V » Tue May 24, 2005 8:38 pm
Have double checked cam timeing, have set it up as it was and should be, havent had the valves out just the head off. Yes had the dizzy out but have checked that a few times and its in all sweet
XS1V
Postby ATAl » Tue May 24, 2005 9:49 pm
Are the valves seating properly? One or more may be bent. :cry:
ATAl
Postby XS1V » Tue May 24, 2005 11:58 pm
:? hmm how would i be able to tell that?? have taken cam covers back off and will compare them to another running bluetop i have
XS1V
4aghe
Postby crispy'86 » Wed May 25, 2005 6:44 pm
I'd say it'd most likelt be distributor timing. I've had numerous occasions where the same thing has happened, helping people out who have had dist. out of engine and put back in. You need to line up the two marks in the shaft 1 being the roll ppin that holds the drive gear on and the other slightly further up the shaft
crispy'86
Postby XS1V » Wed May 25, 2005 6:50 pm
yea i had distributer sweet, done a few before, have fixed the prob and she runs proper :) re did cam timeing as i followed wrong timeing dots from the previous owner :S but now i have a knock ahhh never ends does it lol
XS1V
Postby ChaosAD » Wed May 25, 2005 7:03 pm
A knock? you did turn the engine over with no sparkplugs installed to get the oil pressure up aye?
Did you check the crank, rods and block with a micrometer prior to ordering the bearings? or just slap in some 'standard' bearings?
ChaosAD
Postby XS1V » Wed May 25, 2005 7:18 pm
Yea standard bearings, toyota guys said it would be all good so..... yea i didnt think anything of it. Yes did turn it over without sparkies first. Could be water pump?? was just an idea my mate had as we think it was on the way out possibly
XS1V
4age
Postby crispy'86 » Wed May 25, 2005 7:48 pm
Ok, now is this a metallic knock?? Like on accleleration????
crispy'86
Postby XS1V » Thu May 26, 2005 12:27 am
does it at idal, gets louder with acceleration, and yup is mettalic
XS1V
Postby Mr Revhead » Thu May 26, 2005 10:42 am
that does not sound good.....
did you measure the crank and block/rod journals? were they in spec?
Postby Jebus » Thu May 26, 2005 2:57 pm
Wasnt an auto motor originally by any chance?
Jebus
4age
Postby crispy'86 » Thu May 26, 2005 6:48 pm
sounds like big end bearing area or even bottom end to me, don't think originaly being an auto would cause any problem as the cranks are same swapping flywheels over etc. I've got an auto engine in my trueno now, no problems like this.
crispy'86
Users browsing this forum: Bing [Bot], Google [Bot] and 22 guests
