snwtoy wrote:It's true..
It looks like it vents into the top of the airbox. But take the top of the airbox off and have a closer look - there's a sealed chamber built into it that the bov is 'venting' into.
snwtoy wrote:It doesn't work. Which would account for the fact it is dead silent in standard form.
CosmoNZ wrote:the *airbox designers* are a bit retarded?
Santa'sBoostinSleigh wrote:am i right in saying this is a plumb-back design?
i noticed that it was all sealed and bizzo while i was tu-tuing ages ago
i found that if ya remove the pipe from the other end it runs not the best, and if you block the return line it kills the car...
fivebob wrote:snwtoy wrote:It's true..
No it's not true !!8O
If you look a bit closer at the airbox you will find that it is not sealed at all. The chamber vents into the airbox and also supplies air for the idle speed control.snwtoy wrote:It doesn't work. Which would account for the fact it is dead silent in standard form.
Au Contraire, by the looks I'd say it works very well, but you're right about it being quiet, not sure if they meant it to be quiet or if that's just a by-product of the design.
snwtoy wrote:My bad.. I didn't look close enough, I just assumed because it didn't feed into the main intake it went nowhere
Odd that they've incorporated it into the airbox.
Does the idle bypass actually need a rush of air from the bov when you back off the accelerator?
I disconnected the bov from the airbox and put a filter over the hole in the airbox.
Car still seems to run fine, but my boost guage isn't hooked up yet so I can't tell if it's leaking boost. Why would it leak boost when disconnected? Out through the idle bypass? Surely that would have a one-way valve somewhere? Or not given it didn't need it when connected to the arse end of the bov? The idle bypass hose isn't attatched with any clips so I assume it's not under pressure
fivebob wrote: or you will suck unfiltered air into you engine, leak boost and ruin the seat of the valve by trapping grit on the sealing surfaces
RomanV wrote:fivebob wrote: or you will suck unfiltered air into you engine, leak boost and ruin the seat of the valve by trapping grit on the sealing surfaces
Speaking from experience there?
vvega wrote:see you give good advice and nowone belives you
tell them you have a800 hp ct26 and they all wanna by one
somthimes helping people is just a rod for your own back
v
fivebob wrote:*insert good technical details that make snwtoy look like silly 16 yo idiot*
fivebob wrote:But it does feed back into the main intake, it's just not obvious when you look at it.
fivebob wrote:No, not really, but like I said before it doesn't just feed the ISC, it's cleverly feed back into the main airbox in such a manner as to A) not disturb the flow too much, and B) slowly dissapate the pressure.
fivebob wrote:Take my advice and either put it back immediately before you do any damage to the engine from sucking unfiltered air through the bypass, or, if you really must have the Psssst noise, replace it with an aftermarket BOV.
fivebob wrote:It will leak out the vent of the BOV/Bypass valve, the stock valve is designed to use the vaccum of the intake to help it seal when under boost. You must not run it vented to atmosphere or you will suck unfiltered air into you engine, leak boost and ruin the seat of the valve by trapping grit on the sealing surfaces
fivebob wrote:It also acts as a turbo bypass when off boost by sucking air back through the valve.
Mr Revhead wrote:snwtoy: the air bypass valve (BOV) mounts so it vents into the top of the airbox, if it doesnt feed back into there where does it vent to?
snwtoy wrote:Ok, after my re-examination of the top of the airbox:fivebob wrote:But it does feed back into the main intake, it's just not obvious when you look at it.
It doesn't.
Again, it doesn't feed back into the intake/airbox at all. I can provide pictorial evidence if necessary.
As mentioned, I filtered the bypass line.
You're wrong here. As there is no connection between the BOV outlet and the intake, it does not use any intake vacuum whatsoever. Nice theory though.
There is always a higher pressure behind the bov, than at it's outlet, so it will never 'suck' air and grit in anywhere.
The throttle bypass is either a one-way valve, or it is closed when the throttle is opened, so air (boost) cannot leak out through there.
This part is correct, but all I have effectively done is change the source of the air for the throttle bypass, from air from the bov just in front of the throttle, to ordinary filtered air. I can't see this causing trouble, and the engine doesn't seem to mind at all, so long as there is air to suck.
Thoughts?
Users browsing this forum: No registered users and 32 guests
