20v turbo "spark plugs??"
Postby lorolla24 » Sat Jun 04, 2005 6:41 pm
Anybody know what the type of spark plugs to use with 20v turbo with ZE pistons installed?what to use NGK but don't know which grade. going to run between 15-20 psi.
lorolla24
Postby EVLGTZ » Sat Jun 04, 2005 7:09 pm
yep id run BCPR7ES-8s or possibly even one colder BCPR8ES-8s for those higher boost levels.
I think std 20v gap is 1.1? but prob best to use .8 on turbo application so thats what i've recommended above.
These are what I run on my 4agte
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
Postby lorolla24 » Sat Jun 04, 2005 7:11 pm
Is the detail of the spark plug area "hole size and depth" the same between the 16v head and 20v head?
Are those ones you stated NGK?
lorolla24
Postby Lloyd » Sat Jun 04, 2005 7:13 pm
As above, BCPR7ES should do the trick. Never had issues with them in my 4AGTE. 4AGEs are of heat range 5 (I think), 4AGZEs are one colder at 6 so go one colder again with 7.
EDIT- Yes those are NGK codes and they'll be fine for 20V or 16V
Postby EVLGTZ » Sat Jun 04, 2005 7:17 pm
lorolla24 wrote:Is the detail of the spark plug area "hole size and depth" the same between the 16v head and 20v head?
actually good point. i think the 20vs use the BKR std as opposed to BCPR. Therefore if there is such a plug go for a BKR7ES-8
lorolla24 wrote:Are those ones you stated NGK?
yep
EVLGTZ
EVLGTZ
Postby TrouserFxGt » Sat Jun 04, 2005 9:42 pm
EVLGTZ wrote:actually good point. i think the 20vs use the BKR std as opposed to BCPR. Therefore if there is such a plug go for a BKR7ES-8
yeah they are bkr6ep-11 standard.
Alcohol, The cause of and solution to all lifes problems.
H J Simpson.
TrouserFxGt
Postby matt dunn » Sat Jun 04, 2005 10:21 pm
In my 20V turbo I use the standard NGK plug listed for a 20V but the 0.8mm gap ones not the 1.1 listed.
From memory they are BKR6EP.
I run 18 to 20 psi and do not have a problem.
Matt
