pyro_sniper2002 wrote:Factory ECU SHOULD be fine up to about 48v so my electronics lecturer tells me. A car that ran on 48v from factory would be great, thinner wires all around.
Stealer Of Souls wrote:The ECU will most likely have a voltage control circuit in it. Which in theory will handle upto or around 48V...
All_Fours wrote:I remember reading and article once about great plans for all new cars to run on 48volt systems, the idea being that wire sizes could be reduced, in turn reducing cost of wiring, reducing total weight (apparently by a reasonably significant amount), thus improving fuel economy.
That was a good 3 or 4 years ago, since then haven't heard any developments.
Cahuna wrote:
One advantage for a 24V system in a race/performance car could be with the starting system. I know my FXGT tends to turn over quite slowly when warm, which may be due to the compression or dodgy wiring (I dunno, will look during the rebuild). My father used to have plenty of starting problems with his old Escort rally car due to insufficient cranking power on the starter, he solved it by having (from memory) a system where a second battery kicked in when starting the car, which temporarily boosted everything to 24V. No ECUs or fancy electronics to worry about in that old car though...
