wastegate line????
wastegate line????
Postby IH8TEC » Wed Jun 15, 2005 6:53 pm
hey, just wondering if someone can tell me where the other line on the wastegate goes to. and also the other one on the compressor housing.
http://img.photobucket.com/albums/v329/dangot20v/t3turbo.jpg
brendon
Postby Malcolm » Wed Jun 15, 2005 7:17 pm
the other one will be for a factory boost control system of some sort, air will be bled from it to increase boost. Not sure about the one on the compressor housing though
Postby IH8TEC » Wed Jun 15, 2005 7:22 pm
so the one on the wastegate runs to the inlet manifold. and if i plug my boost controller into that line, it will be sweet?
anyone else have a guess as to what the one on the compressor housing is?
Postby Malcolm » Wed Jun 15, 2005 7:28 pm
possibly, different cars do it differently, but as far as I can work out it would need to be open to atmosphere to control boost, with some sort of solenoid to control when (and possibly how much) it opens.
Postby IH8TEC » Wed Jun 15, 2005 7:30 pm
so you think once i get it going, run it with it as it is and see if it leaks or does whatever?
Postby Malcolm » Wed Jun 15, 2005 7:47 pm
well you should block it off at first otherwise it will leak air and the wastegate wont open. Then you can experiment with bleeding air using a boost controller to increase boost
Postby IH8TEC » Wed Jun 15, 2005 8:17 pm
cheers man, i mine just run a line between them, might just be like that little line (the other one off the wastegate to comp housing) then try later putting a boost controller in that line
thanks man
Postby JamesM » Thu Jun 16, 2005 2:09 pm
just to clarify what i can see in the pic...... there is two inlet on the wastegate actuautor and there is one tap on the compressor housing?
and on that pic u have the pipe connected to one of the taps on the actuator and not connected on the other end?..
if this is the case u have two options.. connect the other end of the pipe to the tap on the compressor housing... or block the tap up on the compressor housing and get a longer pipe and connect to the intake plenum. and the other tap on the actuator gets connected to ur boost controller.
Team Megasquirt
1984 AE86
180kW, 600Nm@wheels @ 16.5psi
JamesM
Postby IH8TEC » Thu Jun 16, 2005 7:33 pm
nah that little line is connected on there. thats where that goes originally, bu there are an extra two which is causgn the confusion
Postby dotdog » Thu Jun 16, 2005 11:12 pm
Lol, hope ur not running the $&#$% pos boost controller, im sure that is what toasted my head gasket
dotdog
Users browsing this forum: Bing [Bot] and 27 guests
