Who makes adaptor plates in nz for quads off 20v??
Postby crispy'86 » Thu Jun 09, 2005 10:57 pm
I am after a few ideas on how to make an adaptor plate to go from quad throttle bodies to big port 16v head, or maybe small port head too.
I've seen a few people who have had some made or done them themselves , anyone know who do these in nz???
crispy'86
Postby Logan » Thu Jun 09, 2005 11:21 pm
laser cut a flange and weld it to an old manifold.
Ive been working on a dcoe based adaptor kit, but at this stage its all just a 3d CAD model.
Logan
SR Sold. Onto Other Things
Logan
Postby ChaosAD » Fri Jun 10, 2005 7:21 pm
Theres a place overseas that make a nice manifold for $250US.
Do a search as I remember seeing something about it a while back.
Otherwise, nite parts used to make them.
ChaosAD
Postby TRDWGN » Fri Jun 10, 2005 8:23 pm
Brendan at Niteparts did a conversion, I assume he is still on here under niteB
TRDWGN
Postby Drifter4ag » Fri Jun 10, 2005 8:29 pm
buy my big port one !!!
freaking awesome
Garage |-" '|
Current Rides
AE86 Notchy (Finally through compliance after 5 years)
Vitz RS :D
Previous,
1x SXE10 Altezza, 2xAE111 Caribs, 3xKP60, 2xke35 SR Coupes, 2xAE85s, 2xAE86 Road Car, 1xAE86 Drift Car 182kw@wheels, 1xJZZ30 Drift Car 360ps
Panspeed Special 450ps Drift Car
JZX91 MARK II CHASER
JZX81 MARK II CHASER..... so many more that i forgot....
Drifter4ag
adaptor
Postby crispy'86 » Fri Jun 17, 2005 11:31 pm
I saw the link to the adaptor, $249usd.
Drifter4ag if i bought you're setup i'd have to save for a while to get the money together, hence me asking bout them, have some lined up just need to save money and out aside and pay the guy fo rthem.
crispy'86
Postby NZ_AE86 » Sat Jun 18, 2005 8:56 am
Logan wrote:laser cut a flange and weld it to an old manifold.
Logan
Easy done this was, maybe 1-2hrs to mod a carb manifold to have factory unmod'd 20V throtle bodies fit. This way you can also do big and samll port with ease just by getting the correct monifold to start off with. :D
NZ_AE86
Logan
Easy done this was, maybe 1-2hrs to mod a carb manifold to have factory unmod'd 20V throtle bodies fit. This way you can also do big and small port with ease just by getting the correct monifold to start off with. :D
NZ_AE86
Postby ChaosAD » Sat Jun 18, 2005 12:57 pm
Were the spacings between the webbers and the spacings between the quads the same?
Would it be straight forward to make up an adaptor plate so the quads will bolt straight to and webber/dellorto manifold? even if it meand modifying the quads?
ChaosAD
Postby Logan » Sat Jun 18, 2005 1:27 pm
its close enough to work, espcially with a 3 axis laser cutting machine to shape the ports of the adaptor plate. However the biggest issue is injector placement, for eg it wont work on my 18rg DCOE manifold becuase the manifold is so short there is no room to put injector boss's in the manifold runners, and the fact that there is balance tubes and crap in the way, which leads me back to my 2nd design which is two laser cut flanges, one to suit the t/bs then another flang to suit the head of the target eng, with some bits of ally pipe to join in up.
Logan
Logan
Postby ChaosAD » Sat Jun 18, 2005 2:14 pm
What about modifying the standard silvertop manifold to bolt up to a webber manifold?
ChaosAD
Postby Mr Revhead » Sat Jun 18, 2005 2:29 pm
i know of a place up north that does them
cost is $350 iirc
Postby NZ_AE86 » Sat Jun 18, 2005 2:31 pm
If you are using it on a 4age you can just use the factory injectors and rail as it is in the head. 8)
NZ_AE86
Postby Logan » Sat Jun 18, 2005 2:32 pm
ChaosAD wrote:What about modifying the standard silvertop manifold to bolt up to a webber manifold?
if you thinking of doing it that way you may as well cut and shut a silver top manifold to a 16v manifold.
Logan
Postby suckymotor » Sat Jun 18, 2005 2:33 pm
have a look at www.ae86.co.nz
suckymotor
TS Original Member
Postby ChaosAD » Sat Jun 18, 2005 4:14 pm
I was thinking of welding a tvis plate (with tvis removed) onto the 20v manifold and then getting in there with a die grinder and jbweld. But without actually seeing the 20v manifold I dont know if its possible.
ChaosAD
