rage wrote:is that the test where u get that little umbrella thing stuck into ur pee pee hole, then opened up then pulled out so it scrapes out some cells from inside ur doodle
Muzzie wrote:Never since I break them all the time anyways
RS13 wrote:Muzzie wrote:Never since I break them all the time anyways
Hahahah! You aren't supposed to put them on your head..
HZRDIZ wrote:You loose valuable time when having to fuss over putting the dam thing on... when youre loving a girl an hour...
