Wiring
Wiring
Postby CAMB01 » Fri Jun 24, 2005 9:57 pm
Ok I hav Put an AE92 map sensored 4AGZE into my AE92 FXGT.
I ECU and wiring for it, but i don't want to change the dash wiring to get the thing running. A few plugs need to be changed on the dash wiring to plug into the GZE ECU and engine wiring. Most of the wires are the same colours but then there are others that i have no clue what they do.
Does anybody know what to do here? have a complete wiring diagram for the whole vehicle? A Haynes repair manual or something?
I'm a noob when it comes to wiring.
Previous engine was a T-VIS 4AGE.
I desperately need to get the car running as soon as possible.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby ChaosAD » Fri Jun 24, 2005 10:04 pm
Have a look in the tech section of www.club4ag.com
Also, if you pull the covers off the ecus each pin is labeles with an abreviation. eg spd = speed sensor
ChaosAD
Postby CAMB01 » Fri Jun 24, 2005 10:17 pm
The real problem is the wiring for the ignition (as it is DLI), and dash instrument cluster.
CAMB01
Postby CAMB01 » Sun Jun 26, 2005 12:45 pm
bump
CAMB01
Postby toyota111 » Sun Jun 26, 2005 12:52 pm
i changed my nz new corolla wagon from a 1300 carb into a 4age and changed the intire inside loom from a 85 fx into mine i found that you could match all the dash colors so hopefully you shouldnt have much of a hassle there
but if you want some wiring i got a haines manual
corollafxwagon@hotmail.com
let me know what you want and ill try to send some stuff to you, ill scan it onto my computer
toyota111
Postby CAMB01 » Mon Jun 27, 2005 9:25 pm
bump
CAMB01
Postby toyota111 » Mon Jun 27, 2005 9:29 pm
what else do you need?? or was that not enough??
toyota111
Postby CAMB01 » Mon Jun 27, 2005 11:51 pm
i havn't received the e-mail, did u send an e-mail?
CAMB01
Postby toyota111 » Tue Jun 28, 2005 6:08 pm
yes ill try again
toyota111
