brake fluid constantly disappearing
Postby scope » Thu Jun 30, 2005 9:46 am
hello
i have a ke30 with a 4k and was just wondering why i have to keep topping up the brake fluid?! every day it has noticely gone down and i'm pretty sure it doesn't do this on other cars! :D
cheers for any help
chicken fillet and bacon with everything except onion and bbq, ranch and southwest sauces
current ride: 1980 mazda rx7 series 1
previous rides: ke36 corolla, series 1 rx7, ke30 corolla, ke70 corolla x2
scope
Postby pervert » Thu Jun 30, 2005 9:54 am
A leak?
pervert
Postby Leon » Thu Jun 30, 2005 10:11 am
Check inside the drums to see if you have a wheel cylinder leaking (common). If so, you're going to need to replace both rear wheel cylinders (if one is gone, the other one won't be far behind) and maybe the brake linings too. Usually once they've been soaked in brake fluid, they're stuffed.
brakes
Postby JasonZE » Thu Jun 30, 2005 10:17 pm
leaking wheel cylinders , master cylinder (where you put fluid in) check front calipers are dry,
In some cases it can leak out the master cylinder into the booster and get sucked into the engine and burnt (noticed any smoke??)
JasonZE
Real Life Mechanic
Postby RedMist » Thu Jun 30, 2005 11:41 pm
Have you checked for 50c coins under your pillow?
I've got a similar problem with the Bunderson. Front right braided line somehow gets a bubble in it.... I sware its those funkin fairies!
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
