GT4 20 wrote:......... If you ahven't alreday done so, you can promote more airflow over the rotor by ditching the stone guards which are attached to the hubs - assuming that you don't do lots of gravel driving
Gary
You will be suprice where the car goes to in the track..
kitty litter, gravel traps, big muddy pot holes,... etc etc which not very often, but on the grass is not uncommon. Have you seen any of the drifting footage on tv.. like XSTV?
suckymotor wrote:if you get hold of stevo at 0800brakes he should be able to make up some brake lines for a good price (just put mine in last week) also best to get a set of pads made up with mintex 1166 all round and go with the elf brake fluid this works well have it on my car and never have had brake fade so far
I heard some good and bad stuff about mintex.
Good are from "racer" like you guys which found everything works great and you guys share the experince.
Bad, from rally drivers who have their mintex pad caught on fire!!.. due to heat build up... problem solve after try different brand.
And another one are from a mates car with the "mintex combo setup".. fuild and pads which suppost to "will not out driven them" on a street car that goes to track once in a while. Car owner told be he out driven the pads... at the end of the track day
I haven't tried Mintex myself, so i'm 1/2 here and 1/2 there.... if u know what I mean.
I have new brake line hoses and all new fluid which is less than 1 year old.
Ken,
I think I got... abit of soft pedal(but i doesn't goes all the way to the floor and still does it after the brakes are fully cool down), and ineffective pedal... just abit more travel.... or is that consider as "soft pedal"
When going into the track, 1st lap, i'll have not much brake, which must be due to pad is cold, so I always do warm up for more than 1/2 a lap for the tyres and brakes before going sideway...
So seems like, I need some better fluids and some ducting and will try to make up one of those "brace" thing for the master cyclinder.
