5k compression, how to up it?
Postby 3T-Rona » Mon Jul 04, 2005 6:57 pm
first of all whats standard compression ratio, think i remember sum1 saying a while ago that it was 9:1 or something? was thinking of doing the head gasket and seals etc and wondered if i could give the head a skim to give a bit more compression, sound anygood? anyone know any exact's to crank up the compression to a healthy ratio?
Joseph
3T-Rona
Re: 5k compression, how to up it?
Postby fangsport » Mon Jul 04, 2005 7:28 pm
3T-Rona wrote:first of all whats standard compression ratio, think i remember sum1 saying a while ago that it was 9:1 or something? was thinking of doing the head gasket and seals etc and wondered if i could give the head a skim to give a bit more compression, sound anygood? anyone know any exact's to crank up the compression to a healthy ratio?
Joseph
keep planing until the rods bend from pistons hitting the top of the combustion chamber :wink:
fangsport
Postby 3T-Rona » Mon Jul 04, 2005 7:29 pm
lol seriously ladies
3T-Rona
Postby fangsport » Mon Jul 04, 2005 7:36 pm
seriously, it depends on the CC size as to how much planing will effect the C/R. there are calculations that need to be done.
i have removed 0.042" off my 3T head but am unsure exactly what the new C/R is, possibly around 10.5:1(ish).
fangsport
Postby 3T-Rona » Mon Jul 04, 2005 8:43 pm
yep i understand this much its a 5k so im assuming around 1500cc's the question was more has anyone already done it with decent results and know exactly how much to plane off.
3T-Rona
Postby fangsport » Mon Jul 04, 2005 8:53 pm
when i was reffering to CC size, i was meaning combustion chamber.
fangsport
Postby 3T-Rona » Mon Jul 04, 2005 9:08 pm
:wink: i get ya. yeh i did a work book (apprenticeship) on displacment calculations an such, its easy to work out when u have all the information, stroke, bore diametre etc but other wise its a bit of a pig
3T-Rona
Postby ChaosAD » Mon Jul 04, 2005 10:12 pm
Your gonna have to get out the burrette and measure it. Then plane the head then measure it again to get the new compression ratio
ChaosAD
Postby 2LTR Rona » Mon Jul 04, 2005 10:54 pm
had a KE25 with a worked 3K in it that blew the head gasket ages ago, ended up swapping the 3K block for a 5K, swapped over the CAM, which turned out to be a Stage 3 raging CAM, but the head was where it was all at.
3K head, ported n polished, over sized valve springs running a set of Webber twin 45mm side drafts, from memory it was running around 13:1, below 1200rpm it ran like a tractor :lol: but above that and it had a wee bit of punch 8) surprised a few people that little thing :lol:
2002 Altezza, 1974 KE25
2LTR Rona
Postby spencer » Tue Jul 05, 2005 11:38 pm
I dont know about all 5k's but mine most of the combustion chamber is in the piston as with the 4k-u(twin squish head). So planing the head isnt always the best option as alot would have to be taken away. A shallower dished piston is the best bet, go check out club-k
ms63 crown
spencer
