MOTOR OIL RECOMMEND !
Postby Brolli » Tue Jul 05, 2005 4:03 pm
On the subject of oils, Is there any problems going from a semi synthetic to a full synthetic oil?
I am currently using Valvoline 10-40 semi and was going to go to a 5-30 fully synthetic.
Would it pay to flush the engine before doing so or should it not matter at all ?
Brolli
Postby Adamal » Tue Jul 05, 2005 4:06 pm
Personally, I think a flush is a good idea. Helps get rid of any built up crap sitting in the oilways in your engine
Postby Snoozin » Tue Jul 05, 2005 7:30 pm
Adamal wrote:Personally, I think a flush is a good idea. Helps get rid of any built up crap sitting in the oilways in your engine
Yeap I do a flush every 3 or so changes anyways... the amount of crud that comes out is both scary and surprising! And then I run some clean stuff through and drain it again just to be sure.....
Snoozin
Postby sergei » Wed Jul 06, 2005 9:41 pm
Have been using Castrol R (RS) 10W60 for very long time, my car sees lots of 9000 rpm, lots of traffic driving, does not consume oil ( 220k on the clock).
Dont go below 10W grade, it is too thin, even VVT Cam pulley is very noisy with real thin oil (little bit quieter on blacktops).
Postby LEV_101 » Wed Jul 06, 2005 11:08 pm
how do you get your 20v to go 9000rpm, did you take the rev limit off ??? :lol:
LEV_101
Postby sergei » Thu Jul 07, 2005 12:43 am
Mine's ECU
Postby LEV_101 » Thu Jul 07, 2005 5:09 pm
hahah damn you ... did you get that off trademe ?
LEV_101
