Lowering the compression ratio
Postby no_8wire » Wed Jul 13, 2005 3:04 pm
I know to raise compression in an engine you can shave the head,
but how can you lower the compression?
current compression is 8.0:1
and I want to know how to get it to 7.5:1
4agze....
no_8wire
Postby Akane » Wed Jul 13, 2005 3:20 pm
Low compression pistons.
Postby RomanV » Wed Jul 13, 2005 3:29 pm
Double up on head gaskets, and machine down the top of the pistons. :lol:
Dont actually try this. :?
Why do you want your comression lower than 8:1 anyway?
If you are after higher boost levels, isnt the 4agze supercharger the main problem?
IIRC it produces too much heat at high boost levels.
Postby Mr Revhead » Wed Jul 13, 2005 3:29 pm
thicker headgasket. maybe
why do you want to lower it?
compression is good! :D
Postby Adamal » Wed Jul 13, 2005 3:36 pm
If you're planning on sticking a turbo on it, then 8.0:1 should be fine.
Postby JT » Wed Jul 13, 2005 3:40 pm
Do you even know why you want 7.5:1 or is it just some magical figure that happens to be lower than 8? :lol:
JT
Postby EVLGTZ » Wed Jul 13, 2005 3:47 pm
Shouldnt need to change compression unless your going for a very serious setup
Compressions good as others have said. Means need less boost for more power and better off boost driving
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
Postby no_8wire » Wed Jul 13, 2005 6:25 pm
well.... I thought if I am going to do something I might as well make it good.
I was reading somewhere that if I lower the compression I would be able to run 260 degree cams and 20psi without a worry, which would give in the high 300hp bracjet (apparently)
7.5:1 was what was recomended...
no_8wire
Postby Mr Revhead » Wed Jul 13, 2005 8:34 pm
well EVLGTZ has 250hp at the wheels on 18psi with 8.9:1 compression
so you will need more than 20psi to make the high 300hp mark....
i know of a 20v turbo that runs 25 iirc and has around 320hp at the fly.....
and its had some big bucks spent on it.
i think you may need to lower your goal a bit!
if your set on that figure, and are prepared to spend the $$ then good on ya.
but youll be wanting more compression and a GOOD ecu as starting points!
Compression lowering
Postby GOLDAE86 » Wed Jul 13, 2005 8:46 pm
Either skim the pistons to the compression ratio desired, or machine out the hemispheres in the cylinder head :D
To finish first, first you must finish
GOLDAE86
Real Life Mechanic
Postby Mr Revhead » Wed Jul 13, 2005 8:50 pm
skimming 4agze pistons removes the coating.... and by all accounts its better than HPC stuff......
Lowering compression
Postby GOLDAE86 » Wed Jul 13, 2005 8:52 pm
Whats the coating on the pistons, cause there is nothing wrong with HPC :D
GOLDAE86
Real Life Mechanic
Postby Mr Revhead » Wed Jul 13, 2005 8:58 pm
i dont know, and know ones been able to tell me. some kind of ceramic stuff, looks similar to the stuff that coats the s/c rotors
note i dont know for sure its not as good, but iv been told by a few ppl i trust.
sbut still, not gospel!
