4age leads upgrade....help.
Postby mojask » Wed Jul 20, 2005 11:00 am
#1: MSD 8.5mm Super Conductor Spark Plug Wire
#2: TRD 5mm High Performance Spark Plug Leads
the car is 95 levin bz-g..
should i go for #1 or #2..?
or Genuine toyota part..?
Thanks~
mojask
Postby TRD Man » Wed Jul 20, 2005 12:27 pm
Mojask,
I guess it would come down to how you intend to use your car, what you want to achieve and your budget.
At about $200 a set TRD leads probably aren't much more expensive than the Genuine Toyota leads.
But, unlike other brands, TRD don't make the claim that their leads will improve power, just that they will deliver the optimum spark under harsh conditions.
Are you ever likely to encounter harsh enough conditions for this to become a factor. Probably not.
I've seen some brands' advertising claiming 5hp or sometimes 5% power gains from using their 8 or 8.5mm leads. I've not seen this demonstrated in practice and would be more than a little sceptical.
TRD Man
Postby Jebus » Wed Jul 20, 2005 1:59 pm
Size alone isnt a huge factor, I tested a set of Top Gun 8mm's against 5mm Bosh Super Sports. On one particular lead the 8mm's had 6 ohm of resistance, and on a lead slightly longer the 5mm had only 2 ohm of resistance.
Assuming your motor isnt overly modified I would definately go with the TRD leads. Maybe even Bosh for a slightly cheaper option.
I dont have any experience with MSD leads however.
Jebus
Postby Al » Thu Jul 21, 2005 12:51 pm
Genuine leads. You wont make anymore power with the other two. All you require is a reliable spark.
Al
Postby aesc » Thu Jul 21, 2005 1:04 pm
Genuine leads wont be as expensive as you expect. Email Mr Revhead for a good deal.
I priced up some leads from Ripco the other day at $160! I think genuines are around $100
EX AE101 owner
2013 Ford Focus ST
aesc
Postby Mr Revhead » Thu Jul 21, 2005 1:06 pm
hehe yeah aftermarket leads are damn pricey!
i supplied a set of TRD ones yesterday for $60 LESS than BNT/REPCOs generis replacement ones :lol:
Users browsing this forum: Bing [Bot] and 12 guests
