3k-b carbs or 4k carb? wats better?
Postby rwd_mayhem » Wed Jul 27, 2005 4:43 pm
wanting to replace the $&#$% 4k carb on a 4k, was wondering wat is better to just bolt on twin carbies from a 3k-b or a single 4k carb? both fully standard.
current: 1975 Valiant Regel
rwd_mayhem
Postby SIKTOY » Wed Jul 27, 2005 4:58 pm
Id go with the twin carbs from a 3KB!!!
Thats what ive got and i felt a decent difference across the whole rev range.
Not huge, but noticable.
Hope that helps, if others disagree, by all means correct me.
ALL MEN DIE, NOT ALL MEN TRULY LIVE!
Current: 80 SR Project,
Check Out My Profile, Including CURRENT Pics!
Previous: 90 GT Sedan, 85 FXGT, 77 SR with 18RG, + many more.
Pink shaved pussy pic!!!
SIKTOY
Postby ke_25 » Wed Jul 27, 2005 6:14 pm
there both crap.. twin sidedrafts :D :D
PRESENT: KE35 Sr coupe (4agte project), GTS-T, MX40 Cressida coupe
EX:KE25 SL Coupe, KE30 4 door, KP61 4 door hatch, KE36 2 Door Wagon, AE70 2 Door Sedan, AE101 FXGT
ke_25
Postby wde_bdy » Wed Jul 27, 2005 6:26 pm
If you search you will find plenty of info on better carbs to use.
wde_bdy
Postby Mr Revhead » Wed Jul 27, 2005 9:38 pm
the hting with the twincarbs is you can actully be decreasing the carburation...
depending on how the manifold is set up, the enigne can only (mostly) suck from one throat at a time, and the twin carbs have smaller choke than the singles.
Postby bogjob_kp60 » Wed Jul 27, 2005 9:53 pm
iv got the 3k-b's on the starly. They were running way beter than the 4k carb when i first bolted them up. Now they are running like crap an they are to much of a bastard to tune. If you want fuel economy and easy tuning keep the 4k single, if you want to be a bit quicker and are good at tuning get the twins
bogjob_kp60
Postby KE25-KP30 » Mon Aug 01, 2005 1:04 pm
In my opinion, the 4k carb's the way to go....i've had about 4 sets of twins, and only one set of them ever went ok. Maybe if they were tuned properly it may be a different story?? Who knows :)
KE25-KP30
Users browsing this forum: Google [Bot] and 25 guests
