supercharger on the way out?
Postby nandor markos » Tue Jul 26, 2005 9:28 pm
hey im just wondering if there are any tell tale signs that a supercharger is on the way? as in diferent noises different power feelings, exhaust smoke etc
any advice would be much appreciated
nandor markos
Postby FLAWLES » Tue Jul 26, 2005 11:37 pm
look at the colour of the s/c oil
check for play in bearings
also you will know when u have dropped a sc bearing..............................................they make one hell of a noise
trust me on this one
FLAWLES
Postby nandor markos » Wed Jul 27, 2005 7:40 pm
well i went and saw my the mechanic thats rebuilding my motor and there was not a drop of oil in the supercharger, and just b4 a took it of the road it used to stop boosting when the engine was cold and it started making a high pitch scream when it was boosting
nandor markos
Postby CozmoNz » Wed Jul 27, 2005 8:43 pm
nandor markos wrote:there was not a drop of oil in the supercharger
Now now, whos faults that?
nandor markos wrote:it used to stop boosting when the engine was cold
This means it dropped off boost? it didnt boost in the first place? Did it boost when warm? specifics....
Because boosting when an engines cold is good for it.... right?
nandor markos wrote:and it started making a high pitch scream when it was boosting
Sounds like the supercharger almost seized... could be the belt slipping over the pully... or just a sliping belt...
Rayne For President!
CozmoNz
Postby Adamal » Wed Jul 27, 2005 9:23 pm
The S/C clutch is governed by throttle position, so if you've been hitting boost in the past while the engine was cold, that means you're giving it too much.
I get the feeling that this shall be a rather expensive lesson for you.
Postby evil_si » Wed Jul 27, 2005 10:37 pm
the high pitch squeal,
in my opinion if theres no oil in it the bearings would have collapsed, and will be the 2 rotors scraping against each other, if this has happened they will be fu*ked, as well as the housing and end plates.
evil_si
Postby CozmoNz » Wed Jul 27, 2005 11:31 pm
but if that happened evil_si, wouldnt as soon as the clutch engages, the engine should basicaly stall? the amount of load..... (or belt just slip)
CozmoNz
Postby FLAWLES » Wed Jul 27, 2005 11:34 pm
IF ITS sqelling two things come to mind
belt needs tighting or its pooked
or the s/c puley bearing has colapsed " which is a cheaper option fix it now as this is the cause of the rest off the bearings to fail
and if the rest fail
well evil si sumd it up
FLAWLES
Postby FLAWLES » Wed Jul 27, 2005 11:42 pm
CozmoNz wrote:but if that happened evil_si, wouldnt as soon as the clutch engages, the engine should basicaly stall? the amount of load..... (or belt just slip)
sort off
this is what happened to me
driving to work ..........yea
herd a load bearing failer nosie " not a nice sound "
looked at the boost gauge
it was reading 10 on the vacum side and not going up
sc light was on
and you could here the engine trying to suck air but could not
i was lucky for two reasons
i did not suck in any valve stem seals 8)
and the rotors in the sc jammed solid due to the fact that two of the very small ball bearing poped out and got stuck in between the two rotrs
it made a meal of the sc 12 nothing was salvgable not even the sc clutch
FLAWLES
Postby evil_si » Thu Jul 28, 2005 11:16 am
na its only belt driven should never stall the engine, and when it engages its not at idle so will just slip the belt, or make the supercharger turn,
when the rotors touch each other, the housings or end plates they make a horrible loud squealing noise, much worse than any belt slip
ive had a supercharger fail on a trip, and simply unplugging it is an easy way to get it home, 230km distance, although it is very gutless, but with no adverse results
evil_si
Postby nandor markos » Sun Jul 31, 2005 9:29 pm
well the lack of oil is my fault but i havent owned the car for to long and buying it of a friend which is a dumb idea i thought he would have checked all that
it never made a real bad squell or nothing like what has been described it just sounded like it was boosting a hell of a lot but only reading 7psi and basically the car went nowhere (gutless as) this is when the car was warm, but when the engine was cold it would read zero boost and the charger made no noise
and the cold thrash well probably not the best idea
nandor markos
Postby CozmoNz » Sun Jul 31, 2005 9:33 pm
Id imagine it wouldnt let the supercharger cluch engage if the car is cold >.>
You know... for obvious reasons
CozmoNz
Postby IH8TEC » Sun Jul 31, 2005 10:12 pm
the s/c clucth will engage when the engine is cold
Postby CozmoNz » Sun Jul 31, 2005 10:14 pm
what a silly idea,
BAD TOYOTA BAD BAD! They went to the trouble with Turbo's to not let them above 7psi etc on some cars, and it would have been so much easier to do it on an electronically controlled clutch... but nooooooo
CozmoNz
Postby Lloyd » Sun Jul 31, 2005 10:16 pm
Fill it with oil and see if it goes any better. You get 50mL or it from Toyota for around the $12 mark for trade. Probably need 100mL though depending on how empty it is.
Postby IH8TEC » Sun Jul 31, 2005 10:17 pm
jsut requires sensible drivers to not shove a whole lot of boost in the motor when its cold. i never used to go ove 3000rpm when it was cold
Postby FLAWLES » Sun Jul 31, 2005 10:33 pm
good man
just another thought
it could be the s/c clutch..... go for a boost " when warm " stop pop the hood and see if there is a burning smell coming from the s/c
u mite find that the s/c clutch is poked
FLAWLES
Postby wanado13's » Mon Aug 01, 2005 3:25 pm
I think your screwed man because that same noise happened to me and three weeks later it stopped boostin altogether because it broke. My supercharger also made high pitch squeaking noises and stopped boosting. I had supercharger oil in the charger but when I bought it it was pretty low. If what happened to mine is whats happening to yours your bearings are shot/seized and it will eventually fry your clutch and youl get no boost whatsoever and the squeaking gets worse
wanado13's
