wiring for O2 sensor (4age)
Postby l1ttle_d3vil » Fri Jul 15, 2005 9:54 pm
what wires are needed for the O2 sensor on my 4age bluetop? i know theres a wire which goes to #2 pin on the ECU. are there any other wires i need? and also will a sensor off any vehicle work? mine was broken off while getting couriered...
Postby sergei » Sat Jul 16, 2005 8:25 pm
Just make sure that the sensor is same type as bluetops one, you even can use 3/4 wired sensors instead of 1 wire, just hook up heater wires to ignition switched power/ground... make sure you don't connect the sensor wrong way as you might damage it.
http://www.autoshop101.com/forms/h37.pdf
all about oxygen sensors
Postby XS1V » Sun Jul 17, 2005 4:08 pm
i have an o2 sensor off a blue top here if you need one??
ST205 Group A Rallye #2363
XS1V
Postby l1ttle_d3vil » Mon Aug 01, 2005 9:33 pm
ok ive got the sensor of 4ageflyer now and its different to the one i had before - the extractors are aftermarket ones though. only issue now is ive got two yellow single pin plugs on the end of my loom and they both go to the O2 pin on the ecu...
only one of these plugs fits the plug on the O2 sensor though, but whats the other one for? do i need it for anything? or is meant to go to the ign or something?
Postby l1ttle_d3vil » Fri Aug 05, 2005 8:39 am
bump
Postby sergei » Fri Aug 05, 2005 9:26 am
probably other yellow plug is old skool diagnostic... leave it like it is... unless you have an diagnostic plug already, then I don't know.
Postby l1ttle_d3vil » Fri Aug 05, 2005 8:21 pm
ok cheers, any reason why it would be connected to the O2 pin though?
