Hybrid turbo
Hybrid turbo
Postby willsf1 » Tue Aug 02, 2005 9:23 pm
Im nearing the completion of a gze-gte conversion on my aw11 im gonna run a td04 since i really dont want the lag associated with a t28 or td05. Many people tell me the td04 will be too small, im only running stock injectors on stock ecu but plan to upgrade those soon and I dont want to have to upgrade the turbo then. I was wondering if its possible to put a td05 compressor and housing on a td04? I dont know much about hybrid turbos but figure why machine a td04 comp housing if a td05 one will fit on a td04 core? Any input would be hepful
never drink and drift
willsf1
Postby Truenotch » Tue Aug 02, 2005 9:25 pm
Truenotch
Postby crnkin » Tue Aug 02, 2005 9:41 pm
get a t3/4 hybrid, lag smag youll love the power. Are you running stock 4agze gear (injectors ecu...) or bluetop? If gze, a td04 will be too small, i saw a td04 dyno running 10psi and a link, max power- 113kw atw.
You want a t3/4 running about 15 pound, will be absolutely perfect running 90% duty on the injectors, and youll be up around 160kw atw... just trying to help :)
deaf_homo "currrently yes"
crnkin
Postby flygt4 » Tue Aug 02, 2005 9:52 pm
every1 says they dont care about lag til they have loads of it... tdo4 can do 135-145kw and will still have a fairly usable powerband. if you want any more you are going to have lag , its up to you to decide how much
:? pick your target power figure and choose a turbo that will be capable of that but still retain some response. no point having a moster turbo but not utlising it.
flygt4
Postby evil_si » Tue Aug 02, 2005 10:39 pm
personally id say a td04 is too small, fine for 1500cc's
no a td05 cover wont fit on a td04 core, i pursued this a few years back.
evil_si
Postby Malcolm » Tue Aug 02, 2005 11:13 pm
FWIW someone on this forum has an aw11 that does 12sec 1/4 miles with a td04 IIRC :)
Postby Malcolm » Tue Aug 02, 2005 11:15 pm
also worth noting that GSR's can do 12's on the td04 also, and they're 1.8L 8O
Postby crnkin » Tue Aug 02, 2005 11:53 pm
very true, but you could do 11's on a t3/4 :) and lag is just one tradeoff for mega power i guess...
crnkin
Postby willsf1 » Wed Aug 03, 2005 2:34 pm
Thanks for all the input. I was thinking T3/T4 but im a student on a budget! Also ive become used to the driveability of the sc and dont really want to loose that but was hoping for 150+rwkw. Ive heard of guys using vf8's and td05's but with useable power from 3500-4000? Im not after a drag motor but a more flexible street/track application. Would a td04 supply say 14psi to redline or would the volume be insufficent after say 6500?
willsf1
Postby Malcolm » Wed Aug 03, 2005 3:07 pm
learn to read compressor flow maps and find one for the td04, then you will know! Seriously I think the td04 will be great, and you wont need to worry about upgrading injectors, ecu etc. a t3/t4 of any description would be a waste without fueling upgrades to allow you to use it to it's full potential.
Postby EVLGTZ » Wed Aug 03, 2005 5:37 pm
agree. TD04 is pretty well suited for the standard setup.
Although if ya want to get some real potential out of the motor go bigger with the likes of a T3/T4 or td05h. Lag aint that bad at all and the difference in overally power can certainly make up for it.
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
Postby JT » Wed Aug 03, 2005 5:45 pm
As all_fours said, don't worry about ecu or injectors, they'll be sweet.
Speaking of compressor maps and turbo reading heres a few links:
http://www.turbocalculator.com/how-to-read.html
http://www.gnttype.org/techarea/turbo/turboflow.html
JT
Postby Drifter4ag » Wed Aug 03, 2005 5:54 pm
bah td04 blows goats ..
run either a t25g or ballbearing t28 turbo ..these are your best option for minimal lag and good power..
the t28 can hit 150kw@wheels no probs
but bare in mind that your injectors will be pretty much on their limit at that power
Garage |-" '|
Current Rides
AE86 Notchy (Finally through compliance after 5 years)
Vitz RS :D
Previous,
1x SXE10 Altezza, 2xAE111 Caribs, 3xKP60, 2xke35 SR Coupes, 2xAE85s, 2xAE86 Road Car, 1xAE86 Drift Car 182kw@wheels, 1xJZZ30 Drift Car 360ps
Panspeed Special 450ps Drift Car
JZX91 MARK II CHASER
JZX81 MARK II CHASER..... so many more that i forgot....
Drifter4ag
Postby evil_si » Wed Aug 03, 2005 7:43 pm
i had a td04 14b on a sohc vtec turbo, 1500cc, and it was pushing its max.
evil_si
Postby crnkin » Wed Aug 03, 2005 10:38 pm
Drifter4ag wrote:bah td04 blows goats ..
I agree with matt, look at his dyno graphs! cant argue with that!
crnkin
Postby Ako » Thu Aug 04, 2005 10:11 am
Which SIZE of td04? There's 9b's, 11G's, and 13G compressor wheels on them, makes a lot of difference. If its not enough for you, go up to an ex - VR4 td05h-14b, that'll be MORE than enough and its comparable in size to the T28. Also only costs about 250-300 second hand....
Ako
Postby willsf1 » Thu Aug 04, 2005 11:42 am
Thakns again for the input I think a td05 is on the cards once i get feul and comp sorted. The td04 is out of a late wrx not sure on the specs and turbo flow charts only tell half the story , depends on geometry and VE of the engine. The "real world" of experience is much more hepful.
Cheers Will
willsf1
Postby B-style » Sun Aug 07, 2005 3:33 pm
my old setup was with a td04, on 10psi it made 137fwkw, but i'm going for bigger cos i want more power!
1997 honda integra type r
1992 toyota levin gt-z turbo
B-style
