Looking at getting some for my AE-85 but "Hand assembled in Taiwan" dosent sound to good, especially when they are $1550
K Sport Adjustables
fangsport wrote:buy at your own peril. they may look fancy, but (as stated above) there are cheaper more user friendly ways of doing this , with parts and service available locally. a set of Bilsteins with threaded collars and springs would possibly give change from $1k.
ChaosAD wrote:I dont think the rear shock mounts on the ae86 are designed to have springs fitted to them, and arent strong enough.fangsport wrote:buy at your own peril. they may look fancy, but (as stated above) there are cheaper more user friendly ways of doing this , with parts and service available locally. a set of Bilsteins with threaded collars and springs would possibly give change from $1k.
Sec hand maybe. But brand new would probably be over 2k.
fangsport wrote: the fact that they supply a normal coil spring to fit the standard platform, suggests that the set-up is a mis-matched pile of poo.
fangsport wrote: considering you can't coil-over the rears without turreting and modifying diff mounts, i havn't allowed for rear coil-overs
gdsup wrote:fangsport wrote: considering you can't coil-over the rears without turreting and modifying diff mounts, i havn't allowed for rear coil-overs
so does that mean what you suggested to be a mis-matched poo
fangsport wrote:i was quoted less than $600 for the Bilsteins (valves to suit), the collars aren't dear and springs??? considering you can't coil-over the rears without turreting and modifying diff mounts, i havn't allowed for rear coil-overs.
ChaosAD wrote:
MATE Hook me up!
$600 for a pair of billies valved to suit is a damn good deal considering they usually go for about $500ish per corner, valved to suit. But $600 for all 4 corners![]()
Thats $150 per corner
Threaded sleeves are bout $100, top plates are about $40 and coilover springs are about the same price as normal lowering springs.
And why does everone seem to knock konis? what is actually wrong with them?
