steering fault with ae92 fxgt
Postby deaf_rattle » Fri Aug 05, 2005 8:58 am
I noticed this morning that my car would twitch.
IT was fairly random, and i havent had time to distinguish when exactly it happens or under which conditions.
But it happened under slow acceleration in a straight line.
IT kinda pulls/twitches to the left.
You can fell the steering wheel move, and the whole car goes to the left.
Anyone had this before?
Maybe a worn tie rod? worn bearing?
Postby Mr Revhead » Fri Aug 05, 2005 9:47 am
thats the power of the mighty 4age causeing wheel spin :P
can you reproduce it? did it only happen once?
Postby Cahuna » Fri Aug 05, 2005 10:32 am
I find that torque steer is worse in my Sentra (and my old Swift GTI) when the wheel alignment is out, shimmy can come from wheel balancing issues. You haven't clobbered a kerb or something recently?
I also had a vibration and pull in the Sentra a couple of years back, it would happen under both acceleration or a constant throttle load. Doing a couple of tight turns on full lock would fix it, then it would come back again after a while. My mechanic fixed it once and for all at the next service, from memory he said it was a stuffed wheelbearing.
We know that four-wheel drive doesn't work in a racing car, and I proved to myself that it doesn't work very well for rallycross. I'm absolutely convinced that it has no future in rallying, either, even if the regulations allowed it. - Roger Clark (rallying legend), circa 1976
Cahuna
Postby THA SHZ » Fri Aug 05, 2005 3:46 pm
also check ur tyres , u could find tht u may have a separated tyre 8)
THA SHZ
Postby deaf_rattle » Fri Aug 05, 2005 4:46 pm
i dont think it was torque steer, i have felt that alot since getting back in the drivers seat of a fwd.
It was really wierd, it felt like the front left wheel had hit a pot hole and caused it to pull to one side, i thought that i mustve hit one, but then it happened a few more times and no sign of pot holes behind me.
Might have to jack it up tomorrow and have a look.
I will try and see what conditions it happens under on my way home from work.
Postby deaf_rattle » Fri Aug 05, 2005 6:50 pm
i dont know too m uch about fwd diffs, but i think my diff is on its way out.
seems to happen most around gear changes.
And not necessarily if giving it revs.
might be time for a new gearbox
Postby Mr Revhead » Fri Aug 05, 2005 7:16 pm
very unusual for the diff to fail in those...... and doesnt sound like diff symptoms
Postby sergei » Fri Aug 05, 2005 8:39 pm
In my previous gearbox (AE101 20v manual) diff failed, it was loud bang with steering trying to go side to side, then regular small bangs syncrhonous with the speed of the car, it turned out that the spyder gears have munched themsels, broken theeth going every where thru diff area inside gearbox, doing heavy grind on the casing aswell... there is no way to miss that sort og failure...
Postby Mr Revhead » Fri Aug 05, 2005 8:42 pm
no there isnt 8O you rough bugger! :lol:
