Turbo for 4agte
Turbo for 4agte
Postby Charged1 » Thu Aug 04, 2005 2:43 pm
Hi I had my car converted to turbo about six months back and was running a Hitachi ht-18 turbo untill it blew its guts , should I stick to this make , or is there a better option out there , the car did ran very well with this set up while it lasted.
Charged1
Postby EVL GSXR » Thu Aug 04, 2005 2:44 pm
Get a Garret GT25R you'll love it :twisted:
www.lowndvs.co.nz
1997 GSXR750 - 11.23 @ 128mph to date - Round 280kph Top Speed to date
http://toyspeed.blakjak.net/profiles/profile.php?id=793
EVL GSXR
Postby EVLGTZ » Thu Aug 04, 2005 3:42 pm
what type of power were you making at what boost levels?
Generally those turbo's aren't too bad and are pretty cheap and easy to find but its all up to what you want out of it as to what turbo you should go with.
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
Postby Stu- » Fri Aug 05, 2005 9:42 pm
HT18's are pretty good and definitly had no complaints while running one on my car - have since upgraded. Full boost by 3800rpm ish although depends on which exhaust housing is used. Very strong turbos. I'd get one rebuilt possibly with a 360 thrust kit and you'll be set.
Project Thread
Stu-
Postby B-style » Sun Aug 07, 2005 3:19 pm
is the turbo your talking about from an rx s4?
cos i've put one together using a t3 exhaust housing from a r32, but still using the standard exhaust wheel which is damn huge. i just don't want it to lagy!
it's going to put on my ae101 4agze?
what do you reckon? or should i go for something else?
1997 honda integra type r
1992 toyota levin gt-z turbo
B-style
Postby Stu- » Sun Aug 07, 2005 3:47 pm
I can't remember what series it was from but it was a HT18-2s if that helps. Yes the exhaust wheel is huge. From memory I used a milled out RB20 housing. I'd go with a HT18 or a TD05h.
Project Thread
Stu-
Postby 1598cc » Sun Aug 07, 2005 4:46 pm
B-style wrote:is the turbo your talking about from an rx s4?
yeh those turbos work well.. i ranone on my levin up to 20psi and it did the job well with minimal lag.
how does the 360 degree thrust bearing kit make a turbo better?
1598cc
Postby vvega » Sun Aug 07, 2005 4:48 pm
run higer boost for longer without the thrust dieing
v
vvega
Postby Charged1 » Mon Aug 08, 2005 1:09 pm
It was running at 10psi never got round to getting the hp measured , wheres a good place on the shore to have this done , once I get it sorted out , thanks
Charged1
Postby EVLGTZ » Mon Aug 08, 2005 3:13 pm
hey charged1 have not seen ya round the shore.
Best bet is to goto one of the first of the month dyno days at Torque Performance in avondale.
If ya gotta go somewhere on the shore then try shoreperformance but readings from that dyno are only really comparable with others from there. Most seem to goto TP so makes sence to go there and only $50 to do the power run too.
Have you put it down the strip yet?
EVLGTZ
EVLGTZ
Postby evil_si » Mon Aug 08, 2005 4:28 pm
yea its a series 4 turbo with a machined out t3 exhaust housing,
try alltech turbos in glenfield
or daniel at turbo 777 in penrose
evil_si
hm
Postby ezy10s » Mon Aug 08, 2005 5:08 pm
Charged1 wrote:It was running at 10psi never got round to getting the hp measured , wheres a good place on the shore to have this done , once I get it sorted out , thanks
that turbo combination onlys just starts to feel good at 10psi- 15-18psi is where the fun is with that setup
Member #244
Gone fishing until further notice
ezy10s
Postby Stu- » Mon Aug 08, 2005 11:25 pm
I'd agree with that. Ran 15-18 on mine a couple of times and shat a brand new clutch setup pretty easily. Would have loved to have had more fun with that combo but upgraded at the same time as fitting the clutch/lsd.
Project Thread
Stu-
Postby ants_ae92 » Tue Aug 09, 2005 10:13 am
How does the td05 go on your levin evlgtz? What sort of rpm range does that come on full boost? Just interested to see what kind of range the turbo works in on your 4age.
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1548
Current Ride: ae101 1997 White corolla BZ-touring station
Previous Rides: ae92 Levin (smallport 4age, Lowered, 17s, exhaust, intake). Ke70 Station wagon (4k, lowered)
ants_ae92
Postby EVLGTZ » Tue Aug 09, 2005 10:47 am
It goes alright eh.
RPM levels for full boost dependent on load and gear of course but its pretty useable but not silly coming on boost all the time.
And like the HT18s, its pretty avg on only 10psi. Usually have it at 1 bar minimum and more when required.
EVLGTZ
EVLGTZ
Postby suberimakuri » Tue Aug 09, 2005 4:01 pm
yeap, 1 bar mate on t3/4 combo.
Stu, better watch out now with that tune boy. Not sure what it'll do under higher boost yet. Good be like the rest of mine and 12:1 flat. ;)
suberimakuri
Postby flygt4 » Tue Aug 09, 2005 5:42 pm
haha damn you people and your high comp gze pistons... having the low comp ones means im going to have to stupid amounts of boost to get my full potential. :wink:
flygt4
Postby CozmoNz » Tue Aug 09, 2005 5:44 pm
"looks at bazda..."
Nah... i think youll be right... he seemed to do pretty well ;)
Rayne For President!
CozmoNz
Postby suberimakuri » Tue Aug 09, 2005 5:51 pm
smallport high comp mate.... wait and see, second time with t3/4 on this combo. First one was awesome.
suberimakuri
Postby crnkin » Tue Aug 09, 2005 5:52 pm
hot damn i cant wait to see that dyno- 190kw???? ish?
deaf_homo "currrently yes"
crnkin
