How do I make this work?
Postby overcast » Mon Aug 08, 2005 2:23 pm
Help please!!
Got given this headunit from a factory toyota and it didnt come with any wiring diagrams.
Can any one help??
(click for larger images)
Thanks in adavance
Mike
overcast
Postby z|gen » Mon Aug 08, 2005 2:34 pm
easiest thing to do is find the wiring loom for it, or find what it came out of, so you can match the pinouts to the correct wires, take it into an auto sparky or toyota, they should be able to help you out with both.
AE91 SUPERCHARGED COROLLA
z|gen
Postby Mr Revhead » Mon Aug 08, 2005 2:53 pm
dont f**king take it to toyota!
what you need to do is get he plug that goes in the back and then a wiring diagram for the car it came from....
also be prepared for the display to be in japanese......
Postby overcast » Mon Aug 08, 2005 2:56 pm
um thats the problem, it has no loom or no plugs and dont know the car it came from!
overcast
Postby Mr Revhead » Mon Aug 08, 2005 3:00 pm
then your best bet is to start looking through wreckers yards!
toyota wont have any info on it at all.
Postby bigfut » Mon Aug 08, 2005 7:27 pm
i've seen one like that in a jap surf 3 litre turbo if that could help
http://toyspeed.blakjak.net/profiles/profile.php?id=1702
The Harder You Fall The Higher You Bounce!
bigfut
Postby Spannergal » Mon Aug 08, 2005 10:18 pm
probably won't help much, but I've seen one like that in a 98 jap import caldina
Spannergal
