smithers wrote:when my mr2 goes past 5,000 rpm it goes into a noticable 'monotone'. is this tvis? (1992 3sge)
Adydas wrote:The 3SG was introduced in 1986. This engine series was initially available in a FWD, AWD, or mid-ship configuration. Transverse.
he 2nd generation was also available in both NA and Turbo forms, but had a different intake system (and smaller ports). The old TVIS system was replaced ...... On the turbo models the manifold just went straight to the head.
sergei wrote:if it is working leave it on, if it is bung fix it or chuck it away... unless engine is extensevly modiffied then chuk it away... most common problem - ripping/cracking of diaphramm (spelling) inside of accutator, so it will leak vacuum and not hold the butterflies closed.
CozmoNz wrote:smithers wrote:when my mr2 goes past 5,000 rpm it goes into a noticable 'monotone'. is this tvis? (1992 3sge)
This would be tvis, which then went onto acis (instead of 2 runners down to the head same length, one opens one shuts etc, they had 2 but different lengths, (one short, one long) which opened the short one at 5000rpm)
Then i think there was 3 way acis i remember someone telling me (3 individual runners, all different lengths) etc.
Its what they did before vvt i guess, some hondas use i think its acis? which is what makes the noticeable Boobaa.... also the reason why nzcelica had A HONDA CELICA X_X. bahahah
sergei wrote:not quiet, its "variable intake length system" or whatever it is called
