Crankcase pressure
Postby evil_si » Sat Aug 13, 2005 10:24 pm
Andy from the block wrote:[I just received my rocker cover I bought of trademe, its one
with twin cam 16 valve written in red. I compared it to my ze rocker
cover and the outlet is much smaller. Also, looking at the underside
of the covers I saw the ze one is much simpler in terms of plates/baffling
than the other cover. The differnce in design isnt gonna be a problem
would it?
Oh and how hard is it to modify the rocker covers to have additional
outlets?
not to hard, drill a hole in each and weld in some alloy tube, from memory last time i used 3/4 tube and hose.
A lot of the expensive japanese ones dont either, for the reasons i explained above, This kind of catch can is not supposed to have a breather on it as it contravenes emmissions regulations. These sealed types are designed to be put inline as a condenser. A catch can with atmospheric breather filter is of course not supposed to be an inline device. I actually run 1 of each kind in the caldina - that way you retain the benefit of the PCV system as well as preventing any oily vapour entering your intake system.
if it does not have a breather and its not plumbed back to the intake it wont do anything, it has to be able to breathe and vent crankcase pressure.
evil_si
Postby TWSTD » Sun Aug 14, 2005 1:36 pm
evil_si wrote:if it does not have a breather and its not plumbed back to the intake it wont do anything, it has to be able to breathe and vent crankcase pressure.
Of course - i never suggested to run breather lines into a completely sealed catch can - go back and re-read what i wrote.
@@@ Online store NOW OPEN! @@@
Click here!
DPR | HTS | SARD | WALBRO | GARRETT | SPEC | EXEDY | MINTEX | HKS | APEXi | MAPECU | SIMOTA + more!
TWSTD
Postby evil_si » Sun Aug 14, 2005 1:41 pm
no but a lot of guys that buy them dont realise,
evil_si
